Home » Language IDEs » C / C++ IDE (CDT) » Newbie Help: "Launch failed. Binary not found." for c++ on Mac OS X 10.7 Eclipse Indigo
Newbie Help: "Launch failed. Binary not found." for c++ on Mac OS X 10.7 Eclipse Indigo [message #783109] Tue, 24 January 2012 23:31 Go to next message
Here is a screenshot of the problem: imgur.com/e2h2Z (i'm not allowed to post links as a new member)
Hi, I've seen a few threads on this very topic, but either the suggestions didn't work for me or they were too vague for me to understand.
I downloaded the C++ developer tools through eclipse and installed, and I'm trying to run the Hello World program that it comes with. I get the above error when I try to run. I have tried adding the -arch i386 flag to the linker and compiler to no avail. Finally, I made sure the mach-o 64 parser was checked.
I'm really stumped. I can run the program perfectly fine through command line with g++ as well as xcode. There is no output to the console at all when I try to run it.
Thanks.
[Updated on: Tue, 24 January 2012 23:35] by Moderator
Re: Newbie Help: "Launch failed. Binary not found." for c++ on Mac OS X 10.7 Eclipse Indig [message #785221 is a reply to message #783109] Sat, 28 January 2012 12:30 Go to previous messageGo to next message
Have you selected the correct binary parser?
http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Ftasks%2Fcdt_t_proj_parser.htm
As far as I know Mac needs Mach-O Parser...
Klaus
Re: Newbie Help: "Launch failed. Binary not found." for c++ on Mac OS X 10.7 Eclipse Indig [message #785226 is a reply to message #785221] Sat, 28 January 2012 12:42 Go to previous messageGo to next message
Yup, using the mach-o 64 parser.
Re: Newbie Help: "Launch failed. Binary not found." for c++ on Mac OS X 10.7 Eclipse Indig [message #785248 is a reply to message #785226] Sat, 28 January 2012 13:24 Go to previous messageGo to next message
Did you build test.cpp within Eclipse? On the screen shot I miss some generated folders:
Press CTRL+B (or however this key is called on a Mac). After a successfully build you should see a folder "Debug" or "Release" in the Project Explorer view and a virtual Folder Binaries. Now right click on one of the binaries and select Run as > Local C/C++ Application.
Klaus
Re: Newbie Help: "Launch failed. Binary not found." for c++ on Mac OS X 10.7 Eclipse Indig [message #785253 is a reply to message #785248] Sat, 28 January 2012 13:34 Go to previous messageGo to next message
Wow. That was it. Embarrassed
I assumed that the "play" button both built AND run. In Xcode it does both.
THANKS!!!!
Laughing
Re: Newbie Help: "Launch failed. Binary not found." for c++ on Mac OS X 10.7 Eclipse Indig [message #993738 is a reply to message #785248] Tue, 25 December 2012 04:46 Go to previous messageGo to next message
Hello, I use Eclipse Juno on Ubuntu 12.10. I also found error in "Launch Failed, Binary not found",although I run the C and C++ file with run as local C/C++ Application. How to fix the problem. I'm fledling for all Ubuntu, and C. So, hope any help and will be appreciated for it.
Re: Newbie Help: "Launch failed. Binary not found." for c++ on Mac OS X 10.7 Eclipse Indig [message #1600149 is a reply to message #785248] Tue, 03 February 2015 22:53 Go to previous messageGo to next message
Yes, this is how I resolved my problem.
I have a maverick.
I already tried to install the new common line tool from the Apple App Developer. It didn't work even if I chose MAC GCC.
I checked if I have my GCC. I have it. This is command is quite powerful.
Re: Newbie Help: "Launch failed. Binary not found." for c++ on Mac OS X 10.7 Eclipse Indig [message #1600150 is a reply to message #785248] Tue, 03 February 2015 22:55 Go to previous message
Just use Command+B, and you can build all of them without knowing the binary files.
You should check if you have gcc with this command:
sudo ln -s /usr/bin/gcc
the result should be
ln: ./gcc: File exists
If needed, you also need to download Command Line Tools, but I don't see it is needed.
Previous Topic:eclipse luna cdt not work on mac
Next Topic:Saving build order in git using eclipse
Current Time: Sat Jul 26 01:54:32 EDT 2025
Powered by FUDForum. Page generated in 0.06945 seconds
