Problem Exporting RCP Product [message #782160] |
Mon, 23 January 2012 04:30  |
When I'm trying to export a RCP Application with Eclipse Product export wizard, I get this message: "Processing inclusion from feature org.eclipse.equinox.executable: Unable to find plug-in: org.eclipse.equinox.launcher_1.2.0.v20110502. Please check the error log for more details."
I a product and a target definition. I also installed the delta pack and I can find the launcher jar in my eclipse installation.
When I look in the target under tab content. The plugin is there, but the icon is purple/yellow instead of blue yellow like the other plugins. I don't know if this means something.
I googled about this problem, but couldn't find a solution.
I'm using Eclipse Indigo 3.7
Re: Problem Exporting RCP Product [message #783991 is a reply to message #782160] |
Thu, 26 January 2012 17:15   |
Good to know ... I assumed, that the other icon maybe ment, that it was not found or something like this. Ok so this should be no problem...
Yes, I checked the option, then I get the error that it can not find the plugin.
But I could export my application without a native launcher. (Descriped here).
This is just ok, for having a first release for testing. I would prefer to have a native launcher and a customized splash screen instead. I don't know where to look else. Should there be some logs with more detailed information?
When I start the export it is generating the ant scripts and right after that comes the message, that the launcher plugin can not be found...
Best Regards,
Marc
[Updated on: Thu, 26 January 2012 17:15] by Moderator
Re: Problem Exporting RCP Product [message #935821 is a reply to message #782160] |
Sun, 07 October 2012 06:55  |
I had the same problem and was able to solve it:
I am using Eclipse 3.7.2 on Ubuntu 12.04 and it seems that this version is slightly different from the "official" one. The missing plug-in is called org.eclipse.equinox.launcher_1.2.0.dist instead.
To solve this, I downloaded the "official" eclipse 3.7.2 from http://download.eclipse.org/eclipse/downloads/drops/R-3.7.2-201202080800/, extracted the plug-ins org.eclipse.equinox.launcher_1.2.0.v20110502 and org.eclipse.equinox.launcher.source_1.2.0.v20110502 into the delta pack installation plug-in directory and reloaded the delta pack in the target definition.
Finally, I was able to create the product including the native launchers for different platforms.
Hope this works for you, too!
Peter
FUDForum. Page generated in 0.08900 seconds
