Re: Mirror only required dependencies from a Mapped Repository [message #831580 is a reply to message #831554] |
Thu, 29 March 2012 00:08  |
Hi Spencer,
On 03/29/2012 05:11 AM, Spencer Van Hoose wrote:
> Anyone?
> It seems like a design oversight to me that each mapped repository and the rules for mirroring from that repository are
> tightly coupled. Would it not be more flexible to specify a number of source repositories and the items that should be
> mirrored separately? Then one could:
> Mirror a feature from any available source repository.
Not sure why this would matter. The reason you specify a feature below a repository is that it's in that particular
repository that you find the feature.
> Mirror a feature from a repository and also mirror dependencies of that feature from another repository (what I'm trying
> to do)
You can do this provided that all repositories are contributed in the same validation set.
There's an implicit rule that if no features are selected in a repository, then select all. So you will get the desired
effect if you add Indigo and specify one of the features that is already required by the m2e contribution. The 'select
all' rule will then not apply.
A better way of disabling the 'select all' would be great to have. Please file an enhancement request for that.
- thomas
FUDForum. Page generated in 0.03967 seconds
