Home » Archived » BIRT » Reading resultset from ReportDesignHandle?
Reading resultset from ReportDesignHandle? [message #783829] Thu, 26 January 2012 09:46 Go to next message
In my application I dynamically create a ReportDesignHandle with a xml datasource. I also create a OdaDataSetHandle and set a query string (that matches the content of the xml file):
  public DataSetHandle createDataSet(String dataSetName, String dataSourceName, String queryText) {
    OdaDataSetHandle dataSetHandle = elementFactory.newOdaDataSet(dataSetName, "org.eclipse.birt.report.data.oda.xml.dataSet");
    try {
      dataSetHandle.setDataSource(dataSourceName);
      dataSetHandle.setName(dataSetName);
      dataSetHandle.setQueryText(queryText);
    } catch (SemanticException e) {
      logger.error("Data source name: " + dataSourceName + " could not be set!", e);
    return dataSetHandle;
After I have done this I would like to compute a Resultset to see that my query text makes sense and evaluates to working values. Is this possible?
I have tried to create a RunAndRenderTask and a IRunTask using the ReportDesignHandle as input and inspect the corresponding IReportContext and IReportDocument (followed by an IDataExtractionTask) object. But I cannot see any info about my columnMapping and rowMappings from the queryText.
Re: Reading resultset from ReportDesignHandle? [message #783888 is a reply to message #783829] Thu, 26 January 2012 11:59 Go to previous messageGo to next message
You could always use the data engine to test a query:
package REAPI;
import org.eclipse.birt.data.engine.api.DataEngine;
import org.eclipse.birt.data.engine.api.IPreparedQuery;
import org.eclipse.birt.data.engine.api.IQueryResults;
import org.eclipse.birt.data.engine.api.IResultIterator;
import org.eclipse.birt.data.engine.api.IResultMetaData;
import org.eclipse.birt.data.engine.api.querydefn.OdaDataSetDesign;
import org.eclipse.birt.data.engine.api.querydefn.OdaDataSourceDesign;
import org.eclipse.birt.data.engine.api.querydefn.QueryDefinition;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.IDesignEngine;
* Simple BIRT Design Engine API (DEAPI) demo.
public class DataEngineExample {
public static void main( String[] args )
try
extract( );
catch ( Exception e )
e.printStackTrace();
// This function shows how to build a very simple BIRT report with a
// minimal set of content: a simple grid with an image and a label.
static void extract( ) throws Exception
//Configure the Engine and start the Platform
DesignConfig config = new DesignConfig( );
config.setBIRTHome(
"C:/birt/birt-runtime-2_6_1/birt-runtime-2_6_1/ReportEngine");
IDesignEngine engine = null;
OdaDataSourceDesign odaDataSource;
DataEngine de=null;
de = DataEngine.newDataEngine( config, null );
odaDataSource = new OdaDataSourceDesign( "Test Data Source" );
odaDataSource.setExtensionID( "org.eclipse.birt.report.data.oda.jdbc" );
odaDataSource.addPublicProperty( "odaURL",
"jdbc:classicmodels:sampledb" );
//sourceHandle.getProperty("odaURL").toString() );
odaDataSource.addPublicProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver");//sourceHandle.getProperty("odaDriverClass").toString());
odaDataSource.addPublicProperty( "odaUser", "ClassicModels"
);//sourceHandle.getProperty("odaUser").toString() );
odaDataSource.addPublicProperty( "odaPassword", "" );
OdaDataSetDesign odaDataSet = new OdaDataSetDesign( "Test Data Set" );
odaDataSet.setDataSource( odaDataSource.getName( ) );
odaDataSet.setExtensionID(
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
odaDataSet.setQueryText( "Select ORDERNUMBER from orders"
);//dsh.getQueryText() );
de.defineDataSource( odaDataSource );
de.defineDataSet( odaDataSet );
QueryDefinition queryDefinition = new QueryDefinition( );
queryDefinition.setDataSetName( odaDataSet.getName() );
queryDefinition.setAutoBinding(true);
IPreparedQuery pq = de.prepare( queryDefinition );
IQueryResults qr = pq.execute( null );
IResultIterator ri = qr.getResultIterator( );
int cc = ri.getResultMetaData().getColumnCount();
IResultMetaData rsmd = ri.getResultMetaData();
while ( ri.next( ) )
for ( int i = 0; i < cc; i++ )
System.out.print(ri.getValue(rsmd.getColumnName(i+1)) + " ");
System.out.println("");
ri.close( );
qr.close( );
de.shutdown( );
System.out.println("Finished");
// We're done!
Jason
> try {
> set!", e);
> possible?
> queryText.
Re: Reading resultset from ReportDesignHandle? [message #783962 is a reply to message #783888] Thu, 26 January 2012 15:54 Go to previous messageGo to next message
Thanks I will give et a try!
If I manually add eg. a table to the report and drag a colum mapping from the dataset into the details row and save the report its possible to read/print the column mappings:
    OdaDataSetHandle de = (OdaDataSetHandle) ds;
    CachedMetaDataHandle cachedMeta = de.getCachedMetaDataHandle();
    List<?> cols = (List<?>) cachedMeta.getResultSet().getValue();
    for (int i = 0; i < cols.size(); i++) {
      ResultSetColumn rsc = (ResultSetColumn) cols.get(i);
      String name = rsc.getColumnName();
      System.out.println(name);
Is it possible to trigger/populate the cachedMetaData automatically from code after setting the queryText?
Re: Reading resultset from ReportDesignHandle? [message #784507 is a reply to message #783962] Fri, 27 January 2012 11:20 Go to previous messageGo to next message
I am a bit confused on what you are trying to do. If you create a data
set and then a table you can create the column bindings that are
attached to the table using code. Is there a reason you want to add the
cached meta data?
Jason
Re: Reading resultset from ReportDesignHandle? [message #1061838 is a reply to message #784507] Tue, 04 June 2013 06:20 Go to previous message
I am currently trying to read resultset of a dataset using birt java api.
Here is it -
I want to read rptdesign and get the dataset and datasource values using them and dataengine api example I want to execute the dataset and get the result set for my next use.
I am able to get OdaDataSetHandle and OdaDataSourceHandle from rptdesign using following code.
//all report engine initialization code...
//IReportRunnable design = eng.openReportDesign("C:/temp/ttt.rptdesign");
        	  List<OdaDataSetHandle> dataSets = design.getDesignHandle().getDesignHandle().getAllDataSets();
        	  for(OdaDataSetHandle temp : dataSets){
        		  System.out.println("DataSource - "+temp.getQueryText());
        		  System.out.println(temp.getDataSourceName());
        		  /*System.out.println(temp);
        		  if(temp instanceof DataSetHandle){
        			  System.out.println(((DataSetHandle)temp).getDataSourceName());
        	  List<OdaDataSourceHandle> dataSources = design.getDesignHandle().getDesignHandle().getAllDataSources();
        	  for(OdaDataSourceHandle temp : dataSources){
        		  System.out.println("getDriverName - "+temp.getDriverName());
        		  System.out.println(temp.getDisplayName());
But I am not able to convert them into OdaDataSetDesign and OdaDatSourceDesign which is required by the data-engine.
Here is the sample data-engine program
// Configure the Engine and start the Platform
		DesignConfig config = new DesignConfig();
		config.setBIRTHome(" ");
		DataEngine de = null;
		de = DataEngine.newDataEngine(config, null);
		odaDataSource = new OdaDataSourceDesign("Test Data Source");
		odaDataSource.setExtensionID("org.eclipse.birt.report.data.oda.jdbc");
		odaDataSource.addPublicProperty("odaURL", "jdbc:classicmodels:sampledb");
		// sourceHandle.getProperty("odaURL").toString() );
		odaDataSource.addPublicProperty("odaDriverClass","org.eclipse.birt.report.data.oda.sampledb.Driver");// sourceHandle.getProperty("odaDriverClass").toString());
		odaDataSource.addPublicProperty("odaUser", "ClassicModels");// sourceHandle.getProperty("odaUser").toString()
		odaDataSource.addPublicProperty("odaPassword", "");
		OdaDataSetDesign odaDataSet = new OdaDataSetDesign("Test Data Set");
		odaDataSet.setDataSource(odaDataSource.getName());
		odaDataSet.setExtensionID("org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet");
		odaDataSet.setQueryText("Select ORDERNUMBER from orders");// dsh.getQueryText()
		de.defineDataSource(odaDataSource);
		de.defineDataSet(odaDataSet);
		QueryDefinition queryDefinition = new QueryDefinition();
		queryDefinition.setDataSetName(odaDataSet.getName());
		IPreparedQuery pq = de.prepare(queryDefinition);
		IQueryResults qr = pq.execute(null);
		IResultIterator ri = qr.getResultIterator();
		while (ri.next()) {
			for (int i = 0; i < cc; i++)
				System.out.print(ri.getValue(rsmd.getColumnName(i + 1)) + " ");
		ri.close();
		qr.close();
		de.shutdown();
Previous Topic:WebViewer with Internet Explorer
Next Topic:Dynamic Image that changes with parameter
Current Time: Sat Jul 26 12:08:14 EDT 2025
Powered by FUDForum. Page generated in 0.08779 seconds
