EMFStore server running within an AS [message #781100] |
Fri, 20 January 2012 09:33  |
Hi!
I´m pretty new in EMF/EMFStore and I have to do the following but don´t know how to start: I need to start the EMFStore server from within an AS (for ex. JBoss). I search in internet but I didn´t find anything useful o specific to this subject. can anyone help me?
thanks in advance,
Cecilia.-
Re: EMFStore server running within an AS [message #788398 is a reply to message #788263] |
Wed, 01 February 2012 13:57   |
I am answering for Maximilian as he is currently on holidays until next
week. We already build some demonstrator running EMFStore applications
in RAP, it is aboslutly possible to do. Are you using the UI delivered
with the EMFStore, or are you develping this part from scratch?
The only parts which would need some adaptations in my opinion are:
- The login: If you have webapplication you probably want to protect the
application itself with a log-In afterwards you probably do not want to
login again with the emfstore, so this should be forwarded
- Session Management: In a desktop client the local data of a user is
save to its home directory. In the web client this has to be adapted to
create a workspace for every user session depending on the current user.
Both adaptations are absolutly doable. I suggest we have a Skype meeting
to discuss your issue, my Skype name is "JonasHelming"
Jonas
Am 01.02.2012 16:24, schrieb Cecilia Alvarez:
> Hi Maximilian,
> I write you again because I found out that it is possible to integrate
> RCP and RAP to convert the RCP app in a web app, and as EMFStore Server
> is an Eclipse RCP app with no GUI, it is possible to integrate it with
> RAP. Is there anything done within this subject? Is there anything
> planned to do in the future? If not, we will evaluate and separate the
> common functionalities and the RCP-specific and the RAP-specific. We can
> then make a contribution to the group.
> Thanks for your help/answer in advance.
> regards,
> Cecilia.-
Re: EMFStore server running within an AS [message #916816 is a reply to message #788398] |
Wed, 19 September 2012 09:55  |
Hi Jonas,
Is it possible for me to get the demonstrator application running EMFStore clients in RAP?
I'm starting a project on similar lines and would be great if I can learn from your experience.
thanks and regards
namrata
FUDForum. Page generated in 0.05275 seconds
