Class not found mystery [message #783817] |
Thu, 26 January 2012 09:23  |
Hello everyone.
I have the following issue: when I run my app on top of a Virgo Kernel, I get the following intermittent error:
Exception in thread "pool-2-thread-1" org.eclipse.virgo.kernel.osgi.framework.ExtendedNoClassDefFoundError: org/apache/http/impl/cookie/AbstractCookieSpec in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1] in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1] in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1] in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1] in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1] in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:140)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at org.apache.http.impl.cookie.BestMatchSpec.getStrict(BestMatchSpec.java:75)
at org.apache.http.impl.cookie.BestMatchSpec.getVersion(BestMatchSpec.java:209)
at org.apache.http.client.protocol.RequestAddCookies.process(RequestAddCookies.java:202)
at org.apache.http.protocol.ImmutableHttpProcessor.process(ImmutableHttpProcessor.java:108)
at org.apache.http.protocol.HttpRequestExecutor.preProcess(HttpRequestExecutor.java:174)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:452)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:820)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:754)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:732)
at uk.co.igindex.springrest.client.AbstractHTTPClientRequest.execute(AbstractHTTPClientRequest.java:60)
at uk.co.igindex.springrest.client.RequestProxyImpl.executeRequest(RequestProxyImpl.java:300)
at uk.co.igindex.springrest.client.RequestProxyImpl.doGet(RequestProxyImpl.java:247)
at com.iggroup.wt.pendingaccount.client.PendingAccountClientImpl.getPendingAccountProcesses(PendingAccountClientImpl.java:96)
at com.iggroup.wb.workbench.accounts.accountopening.data.PendingAccountsController.getAccountsByStage(PendingAccountsController.java:96)
at com.iggroup.wb.workbench.accounts.accountopening.data.PendingAccountsController.access$000(PendingAccountsController.java:16)
at com.iggroup.wb.workbench.accounts.accountopening.data.PendingAccountsController$GetPendingAccountsByStageJob.run(PendingAccountsController.java:59)
at com.iggroup.wb.core.common.utils.CommonsThreadPool$FixedSizeThreadPool$3.run(CommonsThreadPool.java:72)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedNoClassDefFoundError: org/apache/http/impl/cookie/AbstractCookieSpec in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1] in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1] in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1] in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1] in KernelBundleClassLoader: [bundle=com.springsource.org.apache.httpcomponents.httpclient_4.1.1]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.defineClass(KernelBundleClassLoader.java:242)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:601)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:567)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:490)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:478)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:458)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
In the first place, the stack trace seems to imply that the same bundle that contains the class in question (com.springsource.org.apache.httpcomponents.httpclient) cannot find it at runtime, which is odd.
Secondly, when I inspect bundles in the Virgo console, I can see that bundle com.springsource.org.apache.httpcomponents.httpclient is active and that it correctly contains the class in question (via "clhas" command) and it exports it, as expected.
Finally, the problem is, as I said, intermittent, but I cannot figure out what that may mean.
What may be going wrong?
TIA,
B.
Re: Class not found mystery [message #784414 is a reply to message #784349] |
Fri, 27 January 2012 08:40  |
The output actually means that your bundles can load the needed class. They do not contain the class, but it is exported from bundle 96 (since you have the right imports).
The interesting here is that when there is a problem it seems that all your bundles are not wired to 96 com.springsource.org.apache.httpcomponentns.httpclient.
Are there any logs hinting a problem with the wiring of your bundles? If not we need to compare the OSGi wiring in both cases to check what went wrong.
FUDForum. Page generated in 0.06311 seconds
