Problem with running CVS sources [message #783709] |
Thu, 26 January 2012 04:25  |
I've just started an academic project in which I might need to modify or extend the EDT sources.
I have followed the wiki's EDT:Developer's_Guide_to_Getting_Started_on_EDT (I can't make links yet...) to check out the EDT sources from CVS, and after a bit of struggling I got them working in both Indigo and Helios (should I be using Helios for this or should Indigo work as well?)
Running the project in debug mode I can create som EGL code, but as soon as I try to create a web-application which imports the two widget projects, I get 100 (literally) errors in those two projects. Most of them a related to strLib.default formats or RUILib.INCLIDE_ALL_EXCEPT. In general there seems to be problems with including imports properly.
Am I missing someting or doing something wrong?
I can install the 0.7 and the nightly builds and everything works as a charm, it's only the cvs sources that creates this error. (I'm installing sources into a seperate eclipse installation from the one with build-versions)
Also it seems that I need to have the BIRT extension installed in order for the EDT project to run properly. Is that intended? If so, it should be mentioned in teh guide.
Re: Problem with running CVS sources [message #783841 is a reply to message #783806] |
Thu, 26 January 2012 10:11   |
Morten,
The EUnit plug-ins are only required if you are planning to run the automated EGL language compliance tests for EDT. You probably don't need those right now, and you should be able to either delete these plug-ins, or ignore any errors in these projects when launching a runtime workspace. If you do want to run the EUnit test suite, you will need to add the BIRT extensions to your development workspace.
Regarding the widget issues, I have updated the WIKI page I mentioned above to include a better explanation of the problem and the solution. Even if you are not modifying code in the widget projects, you will still need to check out the latest version of these projects from CVS in your runtime workspace to avoid the compile errors that you are currently seeing. This is due to the fact that the version of the widget projects used by the New Project wizard come from the org.eclipse.edt.ide.ui.resources plug-in, which in your development workspace contains a version of the widget projects that were created a long time ago. To make things a bit more complicated, you can't replace the Dojo widget project (i.e. org.eclipse.edt.rui.dojo_0.7.0 or org.eclipse.edt.rui.dojo.remote_0.7.0) with the version of these projects stored in CVS, since the content for these projects is not updated in CVS either. Each of these Dojo projects is built from two additional projects, which are stored in CVS, and it is these two projects that you will need to check out from CVS.
Hopefully the WIKI now contains enough information for you to resolve the compile errors in your runtime workspace, but let me know if it does not and I can make updates as necessary.
-Brian
Re: Problem with running CVS sources [message #786271 is a reply to message #783841] |
Mon, 30 January 2012 02:53  |
Thanks. I'll have a look at it again.
I'll delete the EUnit packages. Maybe we should update the wiki with a notes saying that errors in Eunit packages can be ignored...
Maybe a link to the widget wiki would be good too.
I've been looking a bit more at it, I'm thinking, that probably i won't need the ibmi sources either...
Are there any descriptions of what the different packages do for reference?
Thanks again
Morten
FUDForum. Page generated in 0.05357 seconds
