Home » Eclipse Projects » Equinox » Performance metrics and commercial deployment info required
Performance metrics and commercial deployment info required [message #78181] Wed, 29 November 2006 09:40 Go to next message
Originally posted by: shaneosullivan1.gmail.com
My company is considering using Equinox as a solution for a pluggable web
architecture. However first we need to know if there are any major
bottlenecks in performance or limitations on particular platforms. Does
anyone know of and performance metrics that have been performed against
Equinox, especially in comparison to other web archetectures?
Also, are there any web platforms that this is known to work on? Most posts
to this list mention using either Tomcat or Jetty - has anyone else used
WebSphere or WebLogic? If so, were any issues encountered that are
particular to that system?
Does anyone know of any commercial applications that either have been
deployed using Equinox, or are in development?
Shane O'Sullivan
Re: Performance metrics and commercial deployment info required [message #78275 is a reply to message #78181] Fri, 01 December 2006 00:01 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
You don't say exactly which parts of Equinox you are considering. In
any event, I don't know of any particular performance metrics or
benchmarks that have been run.
For the basic framework function you may not be aware that Websphere
(the new version) is actually based on Equinox and BEA is basing their
new microkernel server architecture (not sure the right name) on it as
well. There likely are still places that could be improved of course,
but things seem to be working pretty well.
For other parts of Equinox it will really depend. Some bundles are
extremely highly optimized (registry) while others are more classic
reference implementation (DS). Others are largely delegation wrappers
for other things (e.g., the server side stuff just wrappers Jetty or
forwards through requests being handled from the underlying server
infrastructure). It would be interesting actaully to get some numbers
where possible.
Suggestions? Volunteers?
Jeff
Shane O'Sullivan wrote:
> Shane O'Sullivan
Re: Performance metrics and commercial deployment info required [message #78350 is a reply to message #78275] Sun, 03 December 2006 00:36 Go to previous message
Originally posted by: skaegi.sympatico.ca
"Jeff McAffer" wrote...
> where possible.
Yep. This is on the TODO list so I guess I'll volunteer ;)
I did some very basic load testing of the servletbridge a bit more than a
year ago and found that the associated overhead for "servlet" requests was
not noticeable even for incredibly simple servlets. Repeated "resource"
requests on the otherhand were slower since at the time there was no support
for the various HTTP cache control headers however support has since been
added. Most appservers support an in memory resource cache which "might" be
a further optimization worth looking into.
A good question is perhaps what we could use to test. Does anyone know of
any good standard benchmark suites we might use?
> > Hi,
web
I can offer one other anecdotal comment. Compared to large web applications
(say involving >100 jars) OSGi based web applications seem to initialize
noticeably more quickly. I suspect the classloading in OSGi based
applications is better able to target the correct place to do class lookups
but haven't done much analysis here.
posts
As far as I know the servletbridge should work on all app servers that
support servlet 2.3 and later. If an app server doesn't work then a bug
should be logged.
See Jeff's comments in the previous post. There are several groups doing
commercial development using server-side Eclipse.
Previous Topic:Webapps in Equinox
Next Topic:Simplehook sample
Current Time: Tue Sep 16 21:11:05 EDT 2025
Powered by FUDForum. Page generated in 0.05610 seconds
