Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Teneo searches for mapping file(s) even it has been already loaded
[Teneo] Teneo searches for mapping file(s) even it has been already loaded [message #78309] Wed, 04 April 2007 07:14 Go to next message
I have number of emf models and initialization of HbDataStore is taking
a while say 15 seconds.
I am trying to use cacheable (addCacheableFile) mapping file, just to
see if it will reduce the time.
Though I have created and set configuration factory which extends
HbContextImpl and it seems that hibernate is using the cached file. But
once it is loaded. It looks that teneo still searches the mapping file.
[@APPNAME@] DEBUG [main] HbDataStore.mapModel(356) | Searching hbm files
in class paths of epackages
[@APPNAME@] DEBUG [main] StoreUtil.getFileList(501) | >>>> Building or
descriptor file List
[@APPNAME@] DEBUG [main] StoreUtil.getFileList(516) | Try path:
;hibernate.hbm.xml
Parvez
Re: [Teneo] Teneo searches for mapping file(s) even it has been already loaded [message #78326 is a reply to message #78309] Wed, 04 April 2007 07:24 Go to previous messageGo to next message
Hi Parvez,
Yes, Teneo does not check if the configuration uses a cached hbm. To prevent this you have to extend
the HbDataStore (or in 0.8.0 the HbSessionDataStore) and override the mapModel method with an empty
method.
gr. Martin
PC wrote:
> ;hibernate.hbm.xml
> Regards,
> Parvez
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Teneo searches for mapping file(s) even it has been already loaded [message #78340 is a reply to message #78326] Wed, 04 April 2007 07:57 Go to previous message
Thanks for feedback Martin.
I will try that.
Martin Taal wrote:
> Hi Parvez,
> prevent this you have to extend the HbDataStore (or in 0.8.0 the
> HbSessionDataStore) and override the mapModel method with an empty method.
> gr. Martin
> PC wrote:
>> Hi,
>> taking a while say 15 seconds.
>> But once it is loaded. It looks that teneo still searches the mapping
>> file.
>> files in class paths of epackages
>> ;hibernate.hbm.xml
>> Regards,
>> Parvez
Re: [Teneo] Teneo searches for mapping file(s) even it has been already loaded [message #604325 is a reply to message #78309] Wed, 04 April 2007 07:24 Go to previous message
Hi Parvez,
method.
gr. Martin
PC wrote:
> ;hibernate.hbm.xml
> Regards,
> Parvez
The Netherlands
Re: [Teneo] Teneo searches for mapping file(s) even it has been already loaded [message #604329 is a reply to message #78326] Wed, 04 April 2007 07:57 Go to previous message
I will try that.
Martin Taal wrote:
> Hi Parvez,
> gr. Martin
> PC wrote:
>> Hi,
>> file.
>> ;hibernate.hbm.xml
>> Regards,
>> Parvez
Previous Topic:[Teneo] Teneo searches for mapping file(s) even it has been already loaded
Next Topic:Suppress rather than override static JET templates
Current Time: Thu Nov 27 20:51:03 EST 2025
Powered by FUDForum. Page generated in 0.04297 seconds
