Home » Archived » BIRT » Can we have Excel output for each table in Birt designer in different sheets.(Generating Excel output per table layout in Birt design per sheet.)
Can we have Excel output for each table in Birt designer in different sheets. [message #783150] Wed, 25 January 2012 02:01 Go to next message
Thanks for one and all for their inputs to one's problems in Birt.
I am having a query:
If i am having 3 tables in my Birt report design,
Can i generate excel output for each table layout per sheet.
Like there are 3 tables:Name are table1,table2,table3.
i want to have to generate Excel outputs like
sheet1-table1 generated output
sheet2-table2 generated output
sheet3-table3 generated output
Please help me in my query.
Thanks in advance for your inputs.
Thanks & Regards
kishore G
Re: Can we have Excel output for each table in Birt designer in different sheets. [message #783390 is a reply to message #783150] Wed, 25 January 2012 11:23 Go to previous message
Not with the default emitter unless you change the source code.
You may want to look at:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1421-native-excel-emitter-plugin-for-birt/
or
tribix emitters:
http://sourceforge.net/projects/tribix/
I am not certain they do this but they do support multiple Excel Sheets.
Jason
On 1/25/2012 2:01 AM, kishore G wrote:
> Thanks & Regards
> kishore G
Previous Topic:Turn off bookmarks in PDF
Next Topic:get dataSetRow value from client script
Current Time: Sat Jul 26 16:09:34 EDT 2025
Powered by FUDForum. Page generated in 0.44855 seconds
