Home » Archived » BIRT » Placing library in RAP environment
Placing library in RAP environment [message #782729] Tue, 24 January 2012 05:02 Go to next message
Hello everyone,
I have a stupid question. I have a report with library. It is running fine within eclipse but not in my RAP environment. How should I place the my BIRT library in a RAP environment? Now I get the following error:
2012.01.24. 9:22:11 org.eclipse.birt.report.model.core.LayoutModule loadLibrarySilently
WARNING: Syntax error found, and see error details.
Error.DesignFileException.SYNTAX_ERROR - 1 errors found!
1.) org.eclipse.birt.report.model.parser.DesignParserException (code = Error.DesignParserException.FILE_NOT_FOUND, message : The file "ri3_mysql.rptlibrary" is not found.)
at org.eclipse.birt.report.model.core.LayoutModule.loadLibrary(LayoutModule.java:378)
The design reference is the following:
<list-property name="libraries">
<structure>
<property name="fileName">ri3_mysql.rptlibrary</property>
<property name="namespace">ri3_mysql</property>
</structure>
</list-property>
But however I try to place the library file I got the same error.
Gábor
Re: Placing library in RAP environment [message #782835 is a reply to message #782729] Tue, 24 January 2012 09:46 Go to previous messageGo to next message
Is the library in the same folder as the report design?
Jason
On 1/24/2012 5:02 AM, Gabor Grocz wrote:
> Hello everyone,
> loadLibrarySilently
> Error.DesignFileException.SYNTAX_ERROR - 1 errors found! 1.)
> at
> <structure>
> </structure>
> </list-property>
> Gábor
Re: Placing library in RAP environment [message #782855 is a reply to message #782835] Tue, 24 January 2012 10:31 Go to previous messageGo to next message
Hi Jason,
yes there is next to the report.
Re: Placing library in RAP environment [message #782989 is a reply to message #782855] Tue, 24 January 2012 16:49 Go to previous messageGo to next message
I am not very familiar with RAP, but from the log the library is not
being located. When we deploy the BIRT Viewer we set the resource
folder in the web.xml and in the designer it is set in the preferences.
What does the directory to the report look like when deployed in RAP?
Jason
On 1/24/2012 10:31 AM, Gabor Grocz wrote:
> Hi Jason,
Re: Placing library in RAP environment [message #783316 is a reply to message #782989] Wed, 25 January 2012 08:44 Go to previous messageGo to next message
Honestly our implementation doesn't use the viewer inside the app. I use the following code to insert the report:
		try {
			config = new EngineConfig();
			IReportEngineFactory factory = (IReportEngineFactory) Platform
					.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
			engine = factory.createReportEngine(config);
			URL url;
			InputStream fs = null;
			try {
				url = getReportURL();
				fs = url.openStream();
			} catch (MalformedURLException ex) {
				ex.printStackTrace();
			} catch (IOException ex) {
			design = engine.openReportDesign(fs);
			// Create task to run and render the report
			task = engine.createRunAndRenderTask(design);
			// Render the report to HTML
			renderOptions = new HTMLRenderOption();
			renderOptions.setOutputFormat(HTMLRenderOption.HTML);
			renderOptions.setOutputStream(outputStream);
			task.setRenderOption(renderOptions);
			task.run();
			task.close();
			browser.setText(outputStream.toString());
			engine.destroy();
		} catch (EngineException ex) {
So actually I just insert the HTML output into the swt browser. The design and the library are in the same directory and they are on the classpath. Should I set somehow the EngineConfig to find the library?
Re: Placing library in RAP environment [message #783396 is a reply to message #783316] Wed, 25 January 2012 11:30 Go to previous messageGo to next message
You could try setting the resource path in the EngineConfig.
config.setResourcePath("directoryoflibs");
Jason
> try {
> URL url;
> try {
> task.run();
> task.close();
> engine.destroy();
Re: Placing library in RAP environment [message #783813 is a reply to message #783396] Thu, 26 January 2012 09:16 Go to previous messageGo to next message
Hi Jason,
thanks it is working now!
Gábor
Re: Placing library in RAP environment [message #897670 is a reply to message #783813] Wed, 25 July 2012 00:07 Go to previous message
Gabor,
I am having a similar problem. Exactly what was your configuration like and what was the path you added to the config.setResourcePath("path")method?
Previous Topic:Dynamic text with page number
Next Topic:Multiple values for dynamic parameter
Current Time: Wed Jul 23 16:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.05930 seconds
