Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Facet] Serialization mechanisms / CDO integration
[EMF Facet] Serialization mechanisms / CDO integration [message #778599] |
Fri, 13 January 2012 08:27  |
Hi there,
I've been taking a look at the EMF Facet API, and created a simple test
to add some new features to the good ol' library model example. My aim
is to test how the EMF Facet framework behaves when dealing with objects
stored in a CDO repository. My test ends up with a
"DanglingRefernceException":
Caused by: org.eclipse.emf.cdo.util.DanglingReferenceException: The
object "org.eclipse.emf.ecore.impl.EAttributeImpl@4f806802 (name:
location) (ordered: true, unique: true, lowerBound: 0, upperBound: 1)
(changeable: true, volatile: false, transient: false,
defaultValueLiteral: null, unsettable: false, derived: false) (iD:
false)(org.eclipse.emf.ecore.impl.EAttributeImpl)" is not contained in a
resource
According to the exception, the EAttribute is not contained in the
resource. Inspecting a bit shows me the new metadata is added as a new
root to the resource passed to the FacetManager. So, just to have an
overall idea on how the new data is stored: is it structured as a
decorator (pointing to the "faceted" model), both having metadata
definition and actual data?
Víctor.
Re: [EMF Facet] Serialization mechanisms / CDO integration [message #779737 is a reply to message #779696] |
Mon, 16 January 2012 07:38   |
Gregoire,
comments below,
> We never tried to use EMF Facet with CDO.
thanks for your feedback. I currently have some tests created. If you
want, I can send you so you can reproduce it.
Right now it looks more as an issue in the CDO side than in the EMF
Facet side. I'm going to investigate on the issue a bit.
>> Can you send me a full stack trace? This will help me to understand what
>> is appending.
org.eclipse.net4j.util.transaction.TransactionException:
org.eclipse.emf.cdo.util.CommitException:
org.eclipse.emf.cdo.util.DanglingReferenceException: The object
"org.eclipse.emf.ecore.impl.EAttributeImpl@638e8fbd (name: location)
(ordered: true, unique: true, lowerBound: 0, upperBound: 1) (changeable:
true, volatile: false, transient: false, defaultValueLiteral: null,
resource
at
org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOResourceImpl.java:959)
at
org.eclipse.emf.facet.efacet.core.internal.serialization.SerializationManager.saveStructuralFeatureInstanceModel(SerializationManager.java:230)
at
org.eclipse.emf.facet.efacet.core.internal.FacetManager.saveStructuralFeatureInstanceModel(FacetManager.java:62)
at
com.opencanarias.mset.prototype.facets.FacetTest.testFacet(FacetTest.java:51)
at
org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at
org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at
org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at
org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at
org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at
org.junit.runners.BlockJUnit4ClassRunner.runNotIgnored(BlockJUnit4ClassRunner.java:79)
at
org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:71)
at
org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:49)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
at
at
org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:62)
at
org.eclipse.pde.internal.junit.runtime.CoreTestApplication.run(CoreTestApplication.java:23)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: org.eclipse.emf.cdo.util.CommitException:
resource
at
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1083)
at
org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOResourceImpl.java:955)
... 48 more
object "org.eclipse.emf.ecore.impl.EAttributeImpl@638e8fbd (name:
resource
at
org.eclipse.emf.internal.cdo.view.AbstractCDOView.provideCDOID(AbstractCDOView.java:899)
at
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.provideCDOID(CDOTransactionImpl.java:2046)
at
org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.writeValues(BaseCDORevision.java:690)
at
org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.write(BaseCDORevision.java:181)
at
org.eclipse.emf.cdo.internal.common.protocol.CDODataOutputImpl.writeCDORevision(CDODataOutputImpl.java:285)
at
org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.requestingCommit(CommitTransactionRequest.java:151)
at
org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.requesting(CommitTransactionRequest.java:112)
at
org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.requesting(CDOClientRequestWithMonitoring.java:91)
at
org.eclipse.net4j.signal.RequestWithMonitoring.requesting(RequestWithMonitoring.java:163)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedOutput(RequestWithConfirmation.java:117)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:296)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:102)
at
org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:233)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:51)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
at
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:419)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:87)
at
org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:73)
at
org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:108)
at
org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:426)
at
org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:308)
at
org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:80)
at
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1069)
... 49 more
>> Please, Can you tell me which version of EMF Facet you are using?
I'm using HEAD from the SVN repository.
>> So, just to have an overall idea on how the new data is stored: is it
>> structured as a decorator (pointing to the "faceted" model), both
>> having metadata definition and actual data?
> Yes, you're right. Currently, no documentation about the feature is
> written. This will be done for the beginning of May.
Good, looking forward ;)
Cheers!
Víctor
Re: [EMF Facet] Serialization mechanisms / CDO integration [message #782766 is a reply to message #782155] |
Tue, 24 January 2012 06:56   |
Gregoire,
> The stacktrace show that the error appends when you try to save the
> resource containing the facet/additional data.
> This is quite strange because the resource should not contain any
> EAttribute. Is the used facet set attached a dedicated resource?
Yes, it is included in a dedicated resource.
The test-case looks like this:
EObject eObject =
getObjectCDOIfied(ModelTestUtils.getTestResource(TEST_MODEL_2_URI));
CDOObject cdoObject = CDOUtil.getCDOObject(eObject);
// Persist FacetSet
FacetSet facetSet = getFacetSet();
CDOResource facetResource = getNewResource();
facetResource.getContents().add(facetSet);
((CDOTransaction)facetResource.cdoView()).commit();
CDOObject wrappedFacetSet = CDOUtil.getCDOObject(facetSet);
// Create new data corresponding to our new Facet
Facet facet = FacetUtils.getFacet(facetSet, TEST_FACET_NAME);
EAttribute attribute = FacetUtils.getEAttribute(facet,
TEST_FACET_ATTRIBUTE_NAME);
IFacetManager facetManager =
IFacetManagerFactory.INSTANCE.createFacetManager(cdoObject.eResource());
facetManager.set(cdoObject, attribute, "Santa Cruz");
facetManager.saveStructuralFeatureInstanceModel();
String location = facetManager.get(cdoObject, attribute, String.class);
assertEquals("Santa Cruz", location);
Re: [EMF Facet] Serialization mechanisms / CDO integration [message #805396 is a reply to message #800058] |
Thu, 23 February 2012 13:04  |
Gregoire,
thanks for letting me know, although I don't recall asking for a fix but
rather some general information about EMF Facet.
We already discarded EMF Facet and built our own solution, thanks anyway!
Víctor
Gregoire Dupe escribió:
> Hello,
> I'm really sorry but I'm too busy to spend time to debug this problem.
> Furthermore, we do not plan to support the use of EMF Facet with CDO in
> the version 0.2 of EMF Facet.
> If you success to solve the problem by your own, we would be really
> happy to read about that.
> Regards,
> Grégoire
Current Time: Fri Jul 25 05:40:25 EDT 2025
Powered by FUDForum. Page generated in 0.09338 seconds
