Home » Modeling » EMF » Cannot install EMF SDK on Eclipse 3.8M4
Cannot install EMF SDK on Eclipse 3.8M4 [message #782693] Tue, 24 January 2012 03:43 Go to next message
I installed an Eclipse 3.8M4 from:
http://download.eclipse.org/eclipse/updates/3.8milestones/S-3.8M4-201112091447
Then I tried to install the org.eclipse.emf.sdk feature from:
http://download.eclipse.org/releases/juno
It failed, apparently because org.eclipse.emf.cheatsheets depends on Eclipse 4.2:
S-4.2M4-201112092100 contains both:
org.eclipse.ui.workbench_3.103.0.v20111208-1436.jar
org.eclipse.ui.workbench_3.8.0.v20111208-1433.jar
and S-3.8M4-201112091447 contains only:
To reproduce quickly, see the attached script (which can be run on build.eclipse.org).
I remember reading that EMF would be compatible with Eclipse 3.8. But is the full EMF SDK from the Juno update site supposed to be installable in an Eclipse 3.8?
Installing org.eclipse.emf.sdk.feature.group 2.8.0.v20111209-1042.
Installation failed.
Cannot complete the install because of a conflicting dependency.
Software being installed: EMF - Eclipse Modeling Framework SDK 2.8.0.v20111209-1042 (org.eclipse.emf.sdk.feature.group 2.8.0.v20111209-1042)
Software currently installed: Eclipse SDK 3.8.0.I20111209-1447 (org.eclipse.sdk.ide 3.8.0.I20111209-1447)
Only one of the following can be installed at once:
Workbench 3.8.0.v20111208-1433 (org.eclipse.ui.workbench 3.8.0.v20111208-1433)
Eclipse Workbench 3.103.0.v20111208-1436 (org.eclipse.ui.workbench 3.103.0.v20111208-1436)
Cannot satisfy dependency:
From: EMF Cheat Sheets 2.5.0.v20100521-1846 (org.eclipse.emf.cheatsheets 2.5.0.v20100521-1846)
To: bundle org.eclipse.ui.workbench [3.102.0,4.0.0)
From: EMF - Eclipse Modeling Framework SDK 2.8.0.v20111209-1042 (org.eclipse.emf.sdk.feature.group 2.8.0.v20111209-1042)
To: org.eclipse.emf.cheatsheets [2.5.0.v20100521-1846]
From: Eclipse Platform 3.8.0.v20111025-9gF7gHgYG0qBwt9xigwMR1SyTAIPsW0ACf1qVw (org.eclipse.platform.feature.group 3.8.0.v20111025-9gF7gHgYG0qBwt9xigwMR1SyTAIPsW0ACf1qVw)
To: org.eclipse.rcp.feature.group [3.8.0.v20111111-92BiG5NFw3Ez00Bvb-JmNXsx]
From: Eclipse RCP 3.8.0.v20111111-92BiG5NFw3Ez00Bvb-JmNXsx (org.eclipse.rcp.feature.group 3.8.0.v20111111-92BiG5NFw3Ez00Bvb-JmNXsx)
To: org.eclipse.ui.workbench [3.8.0.v20111208-1433]
From: Eclipse Project SDK 3.8.0.v20111208a-7Q83A7DQK3C2g8ru0qGrVANZQK9o2MH9CYhJk1fbGh3lM (org.eclipse.sdk.feature.group 3.8.0.v20111208a-7Q83A7DQK3C2g8ru0qGrVANZQK9o2MH9CYhJk1fbGh3lM)
To: org.eclipse.platform.feature.group [3.8.0.v20111025-9gF7gHgYG0qBwt9xigwMR1SyTAIPsW0ACf1qVw]
From: Eclipse SDK 3.8.0.I20111209-1447 (org.eclipse.sdk.ide 3.8.0.I20111209-1447)
To: org.eclipse.sdk.feature.group [3.8.0.v20111208a-7Q83A7DQK3C2g8ru0qGrVANZQK9o2MH9CYhJk1fbGh3lM]
Re: Cannot install EMF SDK on Eclipse 3.8M4 [message #782746 is a reply to message #782693] Tue, 24 January 2012 05:47 Go to previous messageGo to next message
Nicolas,
I thought EMF 2.8 was being built against Eclipse 3.8 but I'm not sure.
Our built inserts the lower bound based on what we built against. We
plan to change our builds to be based on 3.5. I'll ask Kenn to have a look.
On 24/01/2012 9:43 AM, Nicolas Bros wrote:
Re: Cannot install EMF SDK on Eclipse 3.8M4 [message #786297 is a reply to message #782746] Mon, 30 January 2012 03:38 Go to previous messageGo to next message
I tried again with 3.8M5, and it still doesn't work:
Software currently installed: Eclipse SDK 3.8.0.I20120125-1800 (org.eclipse.sdk.ide 3.8.0.I20120125-1800)
Workbench 3.8.0.v20120123-1720 (org.eclipse.ui.workbench 3.8.0.v20120123-1720)
From: Eclipse Platform 3.8.0.v20120103-2134-9gF7hHf2G25BwvMiyqMMfhz04JllcDTwcl9Cqy3 (org.eclipse.platform.feature.group 3.8.0.v20120103-2134-9gF7hHf2G25BwvMiyqMMfhz04JllcDTwcl9Cqy3)
To: org.eclipse.rcp.feature.group [3.8.0.v20120105-1545-92BkG2FFw3Ez0F0S383nTygo]
From: Eclipse RCP 3.8.0.v20120105-1545-92BkG2FFw3Ez0F0S383nTygo (org.eclipse.rcp.feature.group 3.8.0.v20120105-1545-92BkG2FFw3Ez0F0S383nTygo)
To: org.eclipse.ui.workbench [3.8.0.v20120123-1720]
From: Eclipse Project SDK 3.8.0.v20120105-1545-7Q83A7DQL3C6fdKsz06uirGF4ipo3bpobPaTV23Yj0fR6 (org.eclipse.sdk.feature.group 3.8.0.v20120105-1545-7Q83A7DQL3C6fdKsz06uirGF4ipo3bpobPaTV23Yj0fR6)
To: org.eclipse.platform.feature.group [3.8.0.v20120103-2134-9gF7hHf2G25BwvMiyqMMfhz04JllcDTwcl9Cqy3]
From: Eclipse SDK 3.8.0.I20120125-1800 (org.eclipse.sdk.ide 3.8.0.I20120125-1800)
To: org.eclipse.sdk.feature.group [3.8.0.v20120105-1545-7Q83A7DQL3C6fdKsz06uirGF4ipo3bpobPaTV23Yj0fR6]
Re: Cannot install EMF SDK on Eclipse 3.8M4 [message #786305 is a reply to message #786297] Mon, 30 January 2012 03:43 Go to previous messageGo to next message
Nicolas,
We haven't done the M5 build for the SDK yet. This, i.e., v20111209,
is still the M4 version. Kenn plans to do the build today. I'll ask
that we try to install it into 3.8M5.
On 30/01/2012 9:38 AM, Nicolas Bros wrote:
Re: Cannot install EMF SDK on Eclipse 3.8M4 [message #786563 is a reply to message #786305] Mon, 30 January 2012 10:31 Go to previous message
Kenn published our M5 build today and verified that it installs into
Eclipse 3.8M5 and 4.2M5.
On 30/01/2012 9:43 AM, Ed Merks wrote:
> Nicolas,
>> Hi,
Previous Topic:Can't create ecore from XSD under Helios if XSD is in workspace
Next Topic:Arithmetic Operations on EObjects / ELists
Current Time: Sun Jul 20 22:07:16 EDT 2025
Powered by FUDForum. Page generated in 0.08668 seconds
