Home » Newcomers » Newcomers » workspace organization
workspace organization [message #782398] Mon, 23 January 2012 11:47 Go to next message
This is WRT java, but I notice similar issues with the workspace in perl, C, C++, and js.
I'd like to have a folder in my workspace to group related projects together. Since I can't create a top level folder, I used a "project". Inside, the individual projects are in separate source folders. However, they do no require or involve one another. Some of them contain packages and a short demo, usually, Demo.java.
This is a problem because trying to compile one demo after another one results in a "class Demo already exists" error. I've gotten around this by removing all folders from the build path, then adding the one I want to play with back in, but that is a hassle. I've looked at the build path filters, but AFAICT these cannot be used to isolate multiple folders from each other and leave their contents compilable.
What's the answer to all this? I regularly work in several languages simultaneously, I need to be able to organize the workspace so that functional/programmatic relationships can begin somewhere inside a directory tree, but eclipse seems to preclude this -- they are enforced from the top.
Re: workspace organization [message #782446 is a reply to message #782398] Mon, 23 January 2012 12:57 Go to previous messageGo to next message
> from the top.
What you're attempting is probably misguided. Use Eclipse Help to
discover how the feature of "Working Set" works.
Re: workspace organization [message #782509 is a reply to message #782446] Mon, 23 January 2012 16:06 Go to previous messageGo to next message
>> from the top.
I second the recommendation for using Working Sets.
Also consider using multiple workspaces. What you describe really are
separate projects; you're really fighting against Eclipse by trying to
put them all under a single Project. When I have a group of
somehow-related projects, I put them into their own workspace. You can
even have more than one workspace open at a time, as long as your
computer has enough processing power and memory to handle multiple
instances of Eclipse running simultaneously.
Another option that might really serve you well is to utilize the Mylyn
features of Eclipse. Mylyn focuses/filters almost everything in the IDE
based on the notion of Tasks - the currently active Task has a context
associated with it that includes things like what editors are open,
what's visible in the various navigator views, etc. It even coordinates
with Working Sets, too.
Eric
Re: workspace organization [message #783333 is a reply to message #782509] Wed, 25 January 2012 09:32 Go to previous message
One other point. Projects do not have to reside in the workspace. In fact, it is often better to leave the projects outside the workspace so that you don't get workspace files mixed in with your project files in your SCM (workspace files aren't meant to be shared). This allows you to group all of your projects in "development" folder on your system.
To keep the projects outside the workspace, uncheck the Use Default Location when creating the projects.
Previous Topic:Unable to update Eclipse or install new plug-ins.
Next Topic:getting problem to start Indigo after giving workspace specification
Current Time: Sun Jul 27 23:00:35 EDT 2025
Powered by FUDForum. Page generated in 0.49080 seconds
