Home » Archived » BIRT » Integerating BIRT inside the Web Application(Integerating BIRT inside the Web Application)
Integerating BIRT inside the Web Application [message #782104] Mon, 23 January 2012 01:47 Go to next message
I am new to BIRT. In our application, we have to generate the report using BIRT from POJO instead of direct DB hit.
I followed this vogella.de/articles/EclipseBIRT/article.html
I am able to generate report from Eclipse as well as from Tomcat. As per the link regarding deploying in Tomcat we need to install the BIRT webviewer in Tomcat(seperate Web application from Birt Runtime).
Is it possible, without this BIRT webviewer, can we view the report from our web applications by integerating this Birt runtimes inside our application? Please provide me more details(links) to do this.
balachandar
Re: Integerating BIRT inside the Web Application [message #782408 is a reply to message #782104] Mon, 23 January 2012 11:59 Go to previous messageGo to next message
Yes this is possible. Have a look at this link:
http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1
If you are using the BIRT 3.7 or greater runtime, it no longer has a
plugins or configuration directory. Make sure that if you are using 3.7
or greater that you do not set birt home( ie remove this line
config.setEngineHome("");).
Jason
On 1/23/2012 1:47 AM, balachandar sivalingam wrote:
> balachandar
Re: Integerating BIRT inside the Web Application [message #782413 is a reply to message #782104] Mon, 23 January 2012 11:59 Go to previous messageGo to next message
Jason
> balachandar
Re: Integerating BIRT inside the Web Application [message #782420 is a reply to message #782104] Mon, 23 January 2012 11:59 Go to previous messageGo to next message
Jason
> balachandar
Re: Integerating BIRT inside the Web Application [message #783080 is a reply to message #782420] Tue, 24 January 2012 21:35 Go to previous message
Jason,
I followed the link. It works for me.
balachandar
Previous Topic:BIRT 3.7 Report with Multiple Columns
Next Topic:creating javascript vector from dataSetRow
Current Time: Mon Jul 21 09:22:21 EDT 2025
Powered by FUDForum. Page generated in 0.08313 seconds
