Home » Archived » BIRT » org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred: Invalid javascript ex
org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred: Invalid javascript ex [message #780606] Wed, 18 January 2012 13:18 Go to next message
I have report designed and working in Eclipse.
When I deploy the same report in a linux box, i get the error
org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred: Invalid javascript expression: dataSetRow
The datasetRow exists and same report works in IDE.
I checked if there are multiple javascript js.jar files.
Classpath seems clean.
Is this a bug ? I get this error in Birt 2.5.2
Re: org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred: Invalid javascrip [message #780614 is a reply to message #780606] Wed, 18 January 2012 13:40 Go to previous messageGo to next message
Can you post the report? Is this using jdbc? If so do you have the
driver deployed to your linux box?
Jason
Re: org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred: Invalid javascrip [message #781160 is a reply to message #780614] Fri, 20 January 2012 14:22 Go to previous messageGo to next message
I'm using scripted data source.
All the data is coming from stored procedures, I cannot use jdbc datasource.
Even with one simple element, any data type i get the same error.
stack is :
etail : org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred. See next exception for more information.
Invalid javascript expression: dataSetRow["totProdCount"] (Element ID:573)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1214)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1193)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
1937,2-9 22%
Re: org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred: Invalid javascrip [message #782388 is a reply to message #781160] Mon, 23 January 2012 11:30 Go to previous message
Are you calling the stored procedures from the scripted data source?
If so do you have all the jars for the scripted data source in the
scriptlib directory(version <=2.6.2)?
Jason
> datasource.
> stack is :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 1937,2-9 22%
Previous Topic:BigDecimal columns not showing up in chart from HIVE source
Next Topic:not displaying Multiline string value(is String is not having space
Current Time: Sun Jul 27 04:20:05 EDT 2025
Powered by FUDForum. Page generated in 0.03720 seconds
