"Getting more records or rows with data which are not generated in Birt designer preview." [message #778279] |
Thu, 12 January 2012 01:15  |
I would like to Thank one and all for their great efforts and concerns for one's problems in Birt.
I am facing problem while getting data after executing my custom report after deploying into server i.e executing using Birt-Report Engine api.
I have used "Design Engine api" to construct table with checking parameters inside my report design.
Here i am able to get exact result while preview in eclipse Birt perspective designer.
When the same report is deployed or executed from server side coding which uses "Birt-Report Engine api" i.e code to run and generate output from the report design.
Please find an attachment of my sample report which is very close to my problem, where i am getting different Number of rows for every execution of this same report in Birt Report preview.
Please suggest me, Where i am doing wrong or need to check.
Thanks in advance for your great concern.
mkh
FUDForum. Page generated in 0.08743 seconds
