| how to set source and build-folders other than default [message #76711] | Fri, 10 June 2005 13:59  |  |
| Eclipse User  |  |  |  |  | Originally posted by: lehmann-mapson.cnm.de
 I'm using eclipse for a JSP/Servlet project. For this, I'd like to have
 all sources in ./WEB-INF/src and all classes in ./WEB-INF/classes. I
 added a new source-folder in the properties, so eclipse is building
 java-files in ./WEB-INF/src correctly. The problem is, that it neither
 builds them to ./WEB-INF/src nor to ./WEB-INF/classes, but to the base
 folder .
 How can I change this behaviour? I tried to change output folder, but
 then eclipse copies the whole base folder to another folder. Thats not
 what I thought it to do.
 Marten
| Re: how to set source and build-folders other than default [message #76760 is a reply to message #76711] | Fri, 10 June 2005 17:13   |  |
| Eclipse User  |  |  |  |  | Originally posted by: eclipse.rizzoweb.com
 Marten Lehmann wrote:
 > Hello,
 > folder .
 What you may have overlooked is that the root folder of your Project
 (what you call the base?) is still set as a source location. Since your
 source is elsewhere, you need to remove the root folder from the list of
 source locations.
 Keep in mind that the Eclipse builder will go through all Source
 Locations, compile any .java files it finds and copy any non-.java files
 to the output location. That is most likely what you're seeing.
 HTH,
 Eric
| Re: how to set source and build-folders other than default [message #78165 is a reply to message #76807] | Wed, 15 June 2005 11:17  |  |
 > Well,
 > just another question: I set WEB-INF/classes as output-folder now and
 > classes are build to this folder indead. But why isn't this folder shown
 > in the Package Explorer window any longer? I can see WEB-INF/lib
 > WEB-INF/tmp and WEB-INF/work (created by the web-webcontainer), but not
 > WEB-INF/classes.
 The Package Explorer view just does not show the build output directory.
 I've never seen a way to get it to do so (but that doesn't mean it is
 impossible, just that I don't know how).
 Is there a particular reason you want to browse the build output
 location? There is no need to be looking at .class files (in general),
 so I'm curious if whatever you're trying to do might be accomplished
 some other way...
 HTH,
 Eric
FUDForum. Page generated in 0.64732 seconds
