Home » Modeling » EMF » Delegating content types to the global URIConverter
Re: Delegating content types to the global URIConverter [message #781446 is a reply to message #781180] |
Sat, 21 January 2012 08:49 |
Ed Willink Messages: 7661 Registered: July 2009 |
Hi Ed
UML is hardly just 'any one contributor'. The proliferation of UML
namespace URIs now that MDT/UML2 has got unstuck from UML 2.2 makes
working content types mandatory. There is some major pain in store for
UML users post-Juno unless we get content types working effectively. In
making OCL work for and use the enhanced UML, I am variously debugging
the changes and identifying useability challenges.
The problem I'm seeing is not efficiency related; the content types and
handlers are there, so they're already costing; they just aren't useable.
I would like to see the delegation transition from
- use my URIConverter and ResourceRegistryFactories
to
- use globals
also switch to using the global URIConverter, so that globally
registered content handlers are useable, otherwise we will need to
ensure that everyone's local ResourceSet acquires correct local UML
content handlers. Since many/most modeling applications have enhanced
ResourceSets this could cause major headaches.
Ed Willink
On 20/01/2012 15:01, Ed Merks wrote:
> Ed,
> No, as the Java doc suggests, it's not good to modify it.
> * The global static URI converter instance.
> * It's generally not a good idea to modify any aspect of this
> instance.
> * Instead, use a resource set's {@link
> ResourceSet#getURIConverter() local} instance.
> * @since 2.4
> Content handling is an expensive thing and we've gone to lengths to
> avoid it being expensive when it's not being use and to avoid forcing
> everyone to pay an expense that any one contributor decides is worth
> it from their point of view.
> On 20/01/2012 3:47 PM, Ed Willink wrote:
>> Hi Ed
>> Is it possible when running standalone to use content handlers
>> defined for the global URIConverter?
>> The normal ResourceFactory delegation in
>> ResourceSetImpl.getResourceFactoryRegistry using
>> convert(getFactory(...)) carefully uses the global
>> Protocol/Extension/ContentType FactoryMaps but does not pass the
>> global URIConverter so when delegated content types are resolved, the
>> content handlers registered on the local URIConverter rather than
>> those on the global URIConverter are used.
>> Regards
>> Ed Willink
Re: Delegating content types to the global URIConverter [message #781454 is a reply to message #781446] |
Sat, 21 January 2012 09:16 |
Ed Merks Messages: 33163 Registered: July 2009 |
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
Ed,<br>
<br>
Comments below.<br>
<br>
On 21/01/2012 9:49 AM, Ed Willink wrote:
<blockquote cite="mid:jfdu73$s9u$1@news.eclipse.org" type="cite">Hi
Ed
<br>
<br>
UML is hardly just 'any one contributor'.</blockquote>
That's exactly the concern: in my experiences almost every
contributor has exactly this thinking., i.e., they're so important
that their impact on others is totally justified. Remember, I
worked at IBM for a long time.<br>
The proliferation of UML namespace URIs now that MDT/UML2 has got
unstuck from UML 2.2 makes working content types mandatory. There
is some major pain in store for UML users post-Juno unless we get
content types working effectively. In making OCL work for and use
the enhanced UML, I am variously debugging the changes and
<br>
<br>
types and handlers are there, so they're already costing; they
<br>
</blockquote>
The URI converter implementation is created like this:<br>
<blockquote><small> public ExtensibleURIConverterImpl()</small><br>
<small> {</small><br>
<small> this(URIHandler.DEFAULT_HANDLERS,
ContentHandler.Registry.INSTANCE.contentHandlers());</small><br>
<small> }</small><br>
</blockquote>
So all the registered content handlers are available. You seem to
be suggesting that a resource set's content handler list is empty...<br>
<br>
<br>
<br>
to
<br>
- use globals
<br>
</blockquote>
What's missing?<br>
<br>
UML content handlers. </blockquote>
As I suggested above, that should be the case. They should be
populated with the globally registered content handlers. <br>
<blockquote cite="mid:jfdu73$s9u$1@news.eclipse.org" type="cite">Since
many/most modeling applications have enhanced ResourceSets this
<br>
</blockquote>
Too bad things like dependency injection weren't well-understood 10
years ago.<br>
<br>
<br>
<br>
Ed Willink
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Ed,
<br>
<br>
<br>
<br>
<br>
<br>
this
<br>
instance.
<br>
<br>
<br>
* @since 2.4
<br>
<br>
<br>
to avoid it being expensive when it's not being use and to avoid
forcing everyone to pay an expense that any one contributor
decides is worth it from their point of view.
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi Ed
<br>
<br>
<br>
<br>
the global URIConverter so when delegated content types are
resolved, the content handlers registered on the local
URIConverter rather than those on the global URIConverter are
used.
<br>
<br>
<br>
<br>
Ed Willink
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</body>
</html>
Ed Merks
Re: Delegating content types to the global URIConverter [message #781467 is a reply to message #781454] |
Sat, 21 January 2012 10:11 |
Hi Ed
>> and handlers are there, so they're already costing; they just aren't
>> useable.
> So all the registered content handlers are available. You seem to be
There's no problem with URIConverter. It;'s...
>> to
>> - use globals
> What's missing?
In
return
convert
(getFactory
(uri,
Resource.Factory.Registry.INSTANCE.getProtocolToFactoryMap(),
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap(),
Resource.Factory.Registry.INSTANCE.getContentTypeToFactoryMap(),
contentTypeIdentifier,
false));
where the delegation to global occurs, either
URIConverter.INSTANCE could be an additional argument, or
delegate = false could bypass the invocation of getURIConverter to use
the global one.
[Obviously any change now has an established practice corrolary.]
>> Since many/most modeling applications have enhanced ResourceSets this
> years ago.
5 years ago, I had my own 'better' ResourceSet to create 'better'
resources. It was a pain and hazardous imposing this on users.
I subsequently discovered that ResourceSetImpl does so much by
delegation and registries that problems seem soluble anyway.
ResourceSet.eAdapters() can solve almost anything.
Almost every derived ResourceSet that I have seen seems to have an
associated misunderstanding of EMF.
Ed Willink
Re: Delegating content types to the global URIConverter [message #781476 is a reply to message #781467] |
Sat, 21 January 2012 10:55 |
Ed,
Comments below.
On 21/01/2012 11:11 AM, Ed Willink wrote:
> Hi Ed
>>> useable.
I'm not sure what all the discussion about missing content handlers was
about then?
>>> to
>>> - use globals
>> What's missing?
> In
> return
> convert
> (getFactory
> (uri,
> false));
> the global one.
Why? What's so special about the global URI converter?
Note that this was added merely as a convenience to avoid all the places
in the code where we did new ExtensibleURIConverterImpl(), used it once,
and then threw it away. It was not intended to be a centralized place
for people to dump things that would then be generally reused by all
clients. It's clear you're asking for that, and you're even starting to
explain how to implement it, but until you step back and explain why you
need it, I will keep asking why and will ignore the rest as a distraction.
>> years ago.
> Regards
> Ed Willink
Ed Merks
Re: Delegating content types to the global URIConverter [message #781575 is a reply to message #781568] |
Sat, 21 January 2012 17:34 |
<html>
<head>
</head>
Ed,<br>
<br>
The parser reads the priority and this implementation ensures that
the list of handlers is ordered by priority.<br>
<blockquote>public class ContentHandlerRegistryImpl extends
TreeMap<Integer, List<ContentHandler>> implements
ContentHandler.Registry<br>
{<br>
private static final long serialVersionUID = 1L;<br>
<br>
public void put(int priority, ContentHandler contentHandler)<br>
{<br>
Integer integerPriority = priority;<br>
List<ContentHandler> contentHandlers =
get(integerPriority);<br>
if (contentHandlers == null)<br>
{<br>
put(integerPriority, contentHandlers = new
ArrayList<ContentHandler>());<br>
}<br>
contentHandlers.add(contentHandler);<br>
}<br>
<br>
public List<ContentHandler> contentHandlers()<br>
{<br>
ArrayList<ContentHandler> result = new
ArrayList<ContentHandler>();<br>
for (List<ContentHandler> contentHandlers : values())<br>
{<br>
result.addAll(contentHandlers);<br>
}<br>
return result;<br>
}<br>
}<br>
</blockquote>
There's a fairly complete patch for supporting registry reading
stand alone. Perhaps that would be useful?<br>
<br>
<br>
On 21/01/2012 6:22 PM, Ed Willink wrote:
<blockquote cite="mid:jfes8h$l8k$1@news.eclipse.org" type="cite">Hi
<br>
<br>
On 21/01/2012 17:03, Ed Merks wrote:
<br>
<blockquote type="cite">Aren't you populating those things via
plugin.xml registrations?
<br>
</blockquote>
<br>
Yes, when using plugins.
<br>
No, when running standalone, e.g. for me when MWE2 build scripts
that activate Acceleo/QVTo/Xtext/genmodel/custom auto-generation
code.
<br>
<br>
Unfortunately MDT/UML2 has never provided a standalone
initialization routine. It's now pretty mandatory:
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=364419">https://bugs.eclipse.org/bugs/show_bug.cgi?id=364419</a>.
<br>
<br>
[I can't see any evidence that ContentHandler priority is honoured
when populating a URIConverter, but not my problem at present.]
<br>
<br>
<br>
<br>
Ed
<br>
<br>
The issues with the lists is that they're used like this:
<br>
<br>
for (ContentHandler contentHandler :
uriConverter.getContentHandlers())
<br>
<br>
if (contentHandler.canHandle(uri))
<br>
<br>
<br>
So the clients iterate over the list and the list is processed
in order. The list is also editable. It's hard to imagine
inserting delegation to some other global list transparently
under the covers of such a thing...
<br>
<br>
<br>
<br>
On 21/01/2012 4:27 PM, Ed Willink wrote:
<br>
<br>
<br>
I was getting confused about the two globals again. I was
initialising URIConverter.INSTANCE.getContentHandlers() rather
than ContentHandler.Registry.INSTANCE.
<br>
<br>
In the case of ContentHandlers, they are copied into the
extended ResourceSet on construction rather than delegated on
use; seems to create needless lists given that no local
content handlers is a rather common use case.
<br>
<br>
<br>
<br>
Ed Willink
<br>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</body>
</html>
Ed Merks
Current Time: Sun Jun 16 04:45:41 GMT 2024
Powered by FUDForum. Page generated in 0.04643 seconds
