Home » Language IDEs » C / C++ IDE (CDT) » Problem debugging a wxWidget application with Eclipse
Problem debugging a wxWidget application with Eclipse [message #775224] Thu, 05 January 2012 10:38 Go to next message
After installing Eclipse Indigo and wxWidget 2.9.3 I built the "minimal" application
(a sample ditributed with wxWidget)using mingw32.
Debugging works but when I start debugger it opens a window with a message:
Can't find a source file at "../mingw/main.c"
Locate the file or edit the source lookup path to include its location.
When I push F8 (Resume) the application really starts and works.
Before resuming it seems the code is looping somewhere..
Does anybody know how to explain this weird behaviour?
Re: Problem debugging a wxWidget application with Eclipse [message #780926 is a reply to message #775224] Thu, 19 January 2012 18:42 Go to previous messageGo to next message
Something similar is happening to me, as well - some more info on it, disassembly for me shows: "call 0x403b2c <GetCommandLineA@0>" as where it's hanging up at. However if I run the executable by itself, it seems to run just fine. I'm running my own program, just running Eclipse Indigo, no widgets.
Re: Problem debugging a wxWidget application with Eclipse [message #781309 is a reply to message #775224] Fri, 20 January 2012 18:33 Go to previous messageGo to next message
I solved it.
Click on "Debug configurations..."
Set your C/C++ Application and Project.
Click on the tab "arguments" and look at the Working directory: it should be wrong, like:
${workspace_loc:project_name}
Change to something like
${workspace_loc:project_name\Debug}
or whatever is the right path.
Most important, click on the Debugger tab and check Load shared library symbols automatically. Then, on Source tab, check Search for duplicate source files on the path.
That's it.
EDIT:
Also enable autobuild.
[Updated on: Fri, 20 January 2012 19:20] by Moderator
Re: Problem debugging a wxWidget application with Eclipse [message #782527 is a reply to message #781309] Mon, 23 January 2012 17:09 Go to previous messageGo to next message
I did everything as stated, yet I'm still getting the error on mine. The output from gdb in the console is
[New Thread 2596.0x238]
Cannot access memory at address 0x1
[Updated on: Mon, 23 January 2012 17:11] by Moderator
Re: Problem debugging a wxWidget application with Eclipse [message #885784 is a reply to message #782527] Wed, 13 June 2012 11:29 Go to previous messageGo to next message
I have a similar problem. It mentions: "Can't find a source file at "../mingw/gccmain.c" Locate the file or edit the source lookup path to include its location."
Also, when I start debugging, it mentions: No line 20 in file "HelloWorld.cpp". Line 20 is the line where I placed my breakpoint and it's definitely there.
Re: Problem debugging a wxWidget application with Eclipse [message #944709 is a reply to message #775224] Mon, 15 October 2012 00:26 Go to previous messageGo to next message
Right click on the project, go to Debug As - Debug Configurations - Debugger tab - And unclick "Stop on start up at" (which in my case was saying Main). I am not an expert at all, but I think the debugger is trying to stop on the Main at startup and something related to the widget creates the problem (?).
Note: in my case, I was getting the Can't find a source file at "../mingw/main.c"
... with Qt in Eclipse... Hopefully helps...
[Updated on: Mon, 15 October 2012 00:27] by Moderator
Re: Problem debugging a wxWidget application with Eclipse [message #1719651 is a reply to message #944709] Mon, 11 January 2016 00:44 Go to previous message
Ed Bart wrote on Mon, 15 October 2012 04:26
Thanks, My problem solved Smile
Previous Topic:Problem with using <math.h> in Eclipse for C/C++
Next Topic:undefined reference to Structure error
Current Time: Fri Jul 25 05:08:27 EDT 2025
Powered by FUDForum. Page generated in 0.07877 seconds
