How access to servlet context parameters from birt javascript? [message #780873] |
Thu, 19 January 2012 13:46  |
I have a report with a dynamic xml file as datasource.
This file is generated previously to launch the report and is send like a report parameter.
So I declared a datasource with target in "property binding":
"/path_to_folder_with_generated_files/data/" + params["dynamic_xml_file"].value
At this point, go all right.
But i need that "/path_to_folder_with_generated_files/data/" will be
{BIRT_VIEWER_WORKING_FOLDER} + "/data/" + params["dynamic_xml_file"].value
where {BIRT_VIEWER_WORKING_FOLDER} will be the value of this context parameter declared in web.xml deploy descriptor.
How do i access to context parameters from birt javascript?
Environment: Birt 3.7.1 deployed in Glassfish 3.1, ubuntu linux, jdk 1.6
FUDForum. Page generated in 0.30539 seconds
