Nothing comes when I drag a node on to the Editor [message #772319] |
Thu, 29 December 2011 09:06  |
Hi All,
In my GMF Application, When I drag a node and drop it on to the Editor nothing comes.
Error shown below...
!ENTRY org.eclipse.gmf.runtime.diagram.ui 4 4 2011-12-29 19:27:15.368
!MESSAGE execute
!STACK 0
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:521)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:206)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:169)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:156)
at org.eclipse.gef.dnd.AbstractTransferDropTargetListener.handleDrop(AbstractTransferDropTargetListener.java:339)
at org.eclipse.gef.dnd.TemplateTransferDropTargetListener.handleDrop(TemplateTransferDropTargetListener.java:115)
at org.eclipse.gmf.runtime.diagram.ui.internal.parts.PaletteToolTransferDropTargetListener.handleDrop(PaletteToolTransferDropTargetListener.java:89)
at org.eclipse.gef.dnd.AbstractTransferDropTargetListener.drop(AbstractTransferDropTargetListener.java:183)
at org.eclipse.jface.util.DelegatingDropAdapter$3.run(DelegatingDropAdapter.java:211)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.util.DelegatingDropAdapter.drop(DelegatingDropAdapter.java:209)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.dnd.DropTarget.Drop(DropTarget.java:456)
at org.eclipse.swt.dnd.DropTarget$3.method6(DropTarget.java:258)
at org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMObject.java:119)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:363)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:289)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java:172)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at omsbuilder.diagram.application.OmsbuilderApplication.start(OmsbuilderApplication.java:22)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:354)
at omsbuilder.impl.ComponentImpl.eIsSet(ComponentImpl.java:211)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObjectImpl.java:1247)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:407)
at org.eclipse.emf.ecore.util.EcoreUtil$ProperContentIterator.hasNext(EcoreUtil.java:1258)
at org.eclipse.emf.ecore.util.EcoreUtil$ContentTreeIterator.hasNext(EcoreUtil.java:1442)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.attached(ResourceImpl.java:860)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eBasicSetContainer(BasicEObjectImpl.java:1342)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eInverseAdd(BasicEObjectImpl.java:1423)
at org.eclipse.emf.ecore.util.EcoreEList.inverseAdd(EcoreEList.java:292)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:292)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:307)
at omsbuilder.diagram.edit.commands.ComponentCreateCommand.doExecuteWithResult(ComponentCreateCommand.java:63)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.gmf.runtime.diagram.ui.commands.SemanticCreateCommand.doExecuteWithResult(SemanticCreateCommand.java:91)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:134)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
... 50 more
Vinay
Re: Nothing comes when I drag a node on to the Editor [message #781082 is a reply to message #780924] |
Fri, 20 January 2012 08:00   |
The part of stack trace below looks suspicious to me, because normally eIsSet is not calling the list.get().
I may guess that you have some generated @not code here.
In any case, the bottom part of the whole stack trace shows that it is thrown from pure EMF generated code, on attempt to add the new created object into the new container. Can you check that the code whatever change you are doing at the ComponentCreateCommand.doExecuteWithResult(ComponentCreateCommand.java:63) actually works without the GMF?
There are no GMF-specific code executed at the time when it fails -- only your model and basic EMF staff is running there.
Michael "Borlander" Golubev
at Montages Think Tank, Prague, Czech Republic
Montages AG, Zürich, Switzerland
FUDForum. Page generated in 0.03032 seconds
