Home » Archived » BIRT » Data set in dynamic text
Data set in dynamic text [message #779692] Mon, 16 January 2012 05:38 Go to next message
I'm trying to add a result set data in a text element like in http://download.eclipse.org/birt/downloads/examples/reports/DynamicText/DynamicText.html sample, but I can't see the "this report's data sets" folder, although I have more than one data set in the dat explorer view.
Re: Data set in dynamic text [message #780415 is a reply to message #779692] Tue, 17 January 2012 13:43 Go to previous messageGo to next message
That video is from an older version of BIRT. You should see in the
expression builder an entry for Available Column Bindings that allows
you to choose which columns are available.
Jason
Re: Data set in dynamic text [message #780907 is a reply to message #780415] Thu, 19 January 2012 16:32 Go to previous messageGo to next message
I see this if I use expression builder with a data item
index.php/fa/6795/0/
but i see this if I use expression builder with a test item
index.php/fa/6796/0/
So I can use data items, but not use dynamic text
  • Attachment: Immagine.png
    (Size: 16.65KB, Downloaded 2031 times)
  • Attachment: Immagine2.png
    (Size: 16.81KB, Downloaded 2025 times)
Re: Data set in dynamic text [message #781149 is a reply to message #780907] Fri, 20 January 2012 12:57 Go to previous messageGo to next message
Is the dynamic text field in a table?
Jason
Re: Data set in dynamic text [message #782723 is a reply to message #781149] Tue, 24 January 2012 04:52 Go to previous message
OK, that's the problem, the text item was out of a table
Jason Weathersby wrote on Fri, 20 January 2012 12:57
Jason
Previous Topic:Formating x-Axis with Timeintervalls
Next Topic:Crosstabs in RAP application
Current Time: Sun Jul 27 01:59:41 EDT 2025
Powered by FUDForum. Page generated in 0.26791 seconds
