Home » Archived » BIRT » Chart incomplete in PDF
icon5.gif  Chart incomplete in PDF [message #780666] Wed, 18 January 2012 18:00 Go to next message
Hello Community
I have a problem with my BIRT, i'm working in a report to pdf who includes a chart, i'm using scripted datasource...
I have two dataset, one of them should fill the chart's information
I'm sure that both datasets contains information because i put this fields in other section in the report and works ok, show the correct information, but for the chart, i put one field to x-axis and another to y-axis, but only the x-axis are correctly filled, not sure what's the problem...
In 'view report' and 'preview' the chart works ok...
Can you please help me ??
Any ideas??
Thanks a lot!!
  • Attachment: inPDF.jpg
    (Size: 13.24KB, Downloaded 279 times)
  • Attachment: inPreview.jpg
    (Size: 20.77KB, Downloaded 271 times)
Re: Chart incomplete in PDF [message #780885 is a reply to message #780666] Thu, 19 January 2012 14:28 Go to previous messageGo to next message
Can you post the design?
Jason
On 1/18/2012 6:00 PM, Leticia Simental wrote:
> Hello Community
> Any ideas??
> Thanks a lot!!
Re: Chart incomplete in PDF [message #780892 is a reply to message #780885] Thu, 19 January 2012 15:01 Go to previous messageGo to next message
I attached a file with the XML Source for the report...
Also i tried with HTMLRender and get this error:
+ Duplicate aggregation name: COUNT. (Element ID:97)
Duplicate aggregation name: COUNT. ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Duplicate aggregation name: COUNT. (Element ID:97)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1214)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuilderVisitor.visitExtendedItem(ReportQueryBuilder.java:693)
at org.eclipse.birt.report.engine.ir.ExtendedItemDesign.accept(ExtendedItemDesign.java:45)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.build(ReportQueryBuilder.java:256)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.build(ReportQueryBuilder.java:237)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.prepare(AbstractDataEngine.java:180)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execute(ReportExecutor.java:122)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.execute(WrappedReportExecutor.java:60)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciateReportExecutor.execute(SuppressDuplciateReportExecutor.java:42)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportExecutor.execute(LocalizedReportExecutor.java:61)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:178)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at com.arroba.view.QuestionsView.showReport(QuestionsView.java:553)
at com.arroba.view.QuestionsView.jbtnNextActionPerformed(QuestionsView.java:500)
at com.arroba.view.QuestionsView.access$1(QuestionsView.java:484)
at com.arroba.view.QuestionsView$1.actionPerformed(QuestionsView.java:320)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: org.eclipse.birt.chart.exception.ChartException: Duplicate aggregation name: COUNT.
Thanks!
  • Attachment: report.txt
    (Size: 146.88KB, Downloaded 352 times)
Re: Chart incomplete in PDF [message #780895 is a reply to message #780892] Thu, 19 January 2012 15:10 Go to previous messageGo to next message
Click on the chart in the report and select the binding tab in the
properties window. Look at the Puntuation field. Why is it set to a
string? Can you change it to an Integer and try again?
Jason
> Thanks!
Re: Chart incomplete in PDF [message #780897 is a reply to message #780895] Thu, 19 January 2012 15:43 Go to previous messageGo to next message
I changed the datatype to integer, but still get the same error Sad
i can send you my entire project to an email if is necessary
Thanks for your help
Re: Chart incomplete in PDF [message #780900 is a reply to message #780897] Thu, 19 January 2012 15:57 Go to previous messageGo to next message
If I can run it sure. Send it to jasonweathersby at windstream dot net.
On 1/19/2012 3:43 PM, Leticia Simental wrote:
> I changed the datatype to integer, but still get the same error :(
Re: Chart incomplete in PDF [message #788491 is a reply to message #780892] Wed, 01 February 2012 16:58 Go to previous messageGo to next message
I am using Birt 2.5.1.
For some reason, some of the chart is not properly showing in PDF while its working perfectly in html. I notice that in html display chart y-axis showing correct label
while in pdf it shows different.
I used scripted data source and chart is in png format.
Please help !
PDF
index.php/fa/6975/0/
HTML
index.php/fa/6976/0/
Thank you
  • Attachment: 1.png
    (Size: 22.20KB, Downloaded 1290 times)
  • Attachment: 2.png
    (Size: 10.83KB, Downloaded 1295 times)
[Updated on: Wed, 01 February 2012 16:59] by Moderator
Re: Chart incomplete in PDF [message #789218 is a reply to message #788491] Thu, 02 February 2012 13:47 Go to previous messageGo to next message
Can you post the design? Have you tried to resize the chart?
Jason
On 2/1/2012 4:58 PM, Jesh Stha wrote:
> Please help
Re: Chart incomplete in PDF [message #798575 is a reply to message #789218] Tue, 14 February 2012 16:23 Go to previous messageGo to next message
Hi Jason, it's me again
I finally can find my problem (is about datatypes), but can't fixed =(
The situation:
I have a dataset who is filled by a POJO
if(count < stock.size()){
row["puntuationChart"] = stock.get(count).getSectionPoint();
row["sectionChart"] = stock.get(count).getSectionName();
row["resultChart"] = stock.get(count).getSectionResults();
count++;
return true;
return false;
The column named 'puntuationChart' is the problem.... This column is type=Decimal, and I filled it with a POJO's property type = double, just like this example http: //www.vogella.de/articles/EclipseBIRT/article. html (I did the example and works fine).
The only difference between my project and the example project is that in Java i first have a String, then convert to double and then I set it to the POJO's property:
public List<Answer> getAnswerValues(String answerTot) {
String[] answersStr = answerTot.split(",");
List<Answer> answers = new ArrayList<Answer>();
for (int s = 0; s < answersStr.length; s++) {
Answer answer = new Answer();
double point = Double.parseDouble(answersStr[s]);
answer.setSectionPoint(point);
answers.add(answer);
return answers;
When I execute the proyect, get this warning:
Feb 14, 2012 3:10:30 PM org.eclipse.birt.chart.internal.datafeed.ResultSetWrapper initializeMeta
WARNING: Unable to determine data types from resultset
But this warning only is showing when the project is executed, when use the BIRT preview works fine
Could you please help me?
Attached the XML Design
Re: Chart incomplete in PDF [message #799221 is a reply to message #798575] Wed, 15 February 2012 11:11 Go to previous messageGo to next message
Can you add the following to your fetch:
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/datasetevents.txt",
true ) );
out.println( "puntuationChart "+count+"--" +
stock.get(count).getSectionPoint());
out.close();
count++;
return true;
And then verify all the data in the datasetevents.txt file?
Jason
Re: Chart incomplete in PDF [message #799381 is a reply to message #799221] Wed, 15 February 2012 15:29 Go to previous messageGo to next message
Hi Jason
The data looks well, have the information generated in Java:
puntuationChart 0--20
puntuationChart 1--20
puntuationChart 2--20
puntuationChart 3--20
puntuationChart 4--18
puntuationChart 5--17
puntuationChart 6--20
puntuationChart 7--20
puntuationChart 8--20
puntuationChart 9--20
puntuationChart 10--20
puntuationChart 11--20
also, if i set this information in a table, works OK, the problem is only with charts
Re: Chart incomplete in PDF [message #800176 is a reply to message #799381] Thu, 16 February 2012 14:44 Go to previous messageGo to next message
Try leaving it at a string in the java code:
change this code.
to just return a string for the point. Also if you delete the tables
and only have the chart does it work?
I noticed in your table you changing the type to integer.
Jason
On 2/15/2012 3:29 PM, Leticia Simental wrote:
> Hi Jason
> only with charts
Re: Chart incomplete in PDF [message #800317 is a reply to message #800176] Thu, 16 February 2012 18:39 Go to previous messageGo to next message
Hi Jason, thanks a lot but...
Still not working, i changed the datatype as String (for all the columns), got the same error:
Feb 16, 2012 4:59:02 PM org.eclipse.birt.chart.internal.datafeed.ResultSetWrapper initializeMeta
Something that i forgot mention is that 'Point' is the data for Axis-Y, Axis X is filled correctly with column 'Section'
Ammm, the chart does not work, with or without tables
I try restarted a new report from the beginning, really don't understand why doesn't work.... Confused
Attached the rptdesign
Re: Chart incomplete in PDF [message #800329 is a reply to message #800317] Thu, 16 February 2012 19:03 Go to previous messageGo to next message
Sorry, wrong file...
Here the good one
Re: Chart incomplete in PDF [message #800972 is a reply to message #800329] Fri, 17 February 2012 14:19 Go to previous messageGo to next message
I mean to leave it in as a string on the java side but leave it as a
double on the scripted data set. Is there anyway I can run this report?
Jason
> Here the good one
Re: Chart incomplete in PDF [message #800981 is a reply to message #800972] Fri, 17 February 2012 14:30 Go to previous messageGo to next message
I did that too
System.out.println("entre");
answer.setSectionName(strSections[s]);
answer.setSectionPoint(answersStr[s]);
System.out.println(answer.getSectionPoint());
answer.setSectionResults(respuestaBundled(s, (int)point));
return answers;
I have to change the datatype in Java but not in BIRT??
Re: Chart incomplete in PDF [message #800995 is a reply to message #800981] Fri, 17 February 2012 14:51 Go to previous messageGo to next message
When you write out the data points to a file in the fetch method could
you write out the class type too?
stock.get(count).getSectionPoint().getClass();
Jason
On 2/17/2012 2:30 PM, Leticia Simental wrote:
> I did that too
> return answers;
Re: Chart incomplete in PDF [message #801003 is a reply to message #800995] Fri, 17 February 2012 15:08 Go to previous messageGo to next message
Hi Jason
Here the results:
puntuationChart 0--18 class java.lang.String
puntuationChart 1--19 class java.lang.String
puntuationChart 2--16 class java.lang.String
puntuationChart 3--20 class java.lang.String
puntuationChart 4--20 class java.lang.String
puntuationChart 5--20 class java.lang.String
puntuationChart 6--20 class java.lang.String
puntuationChart 7--20 class java.lang.String
puntuationChart 8--20 class java.lang.String
puntuationChart 9--20 class java.lang.String
puntuationChart 10--20 class java.lang.String
puntuationChart 11--20 class java.lang.String
Thanks!
Re: Chart incomplete in PDF [message #801013 is a reply to message #801003] Fri, 17 February 2012 15:21 Go to previous messageGo to next message
Can you run the attached modified report as a test.
Jason
  • Attachment: test.zip
    (Size: 4.65KB, Downloaded 238 times)
Re: Chart incomplete in PDF [message #801031 is a reply to message #801013] Fri, 17 February 2012 15:50 Go to previous messageGo to next message
Same result... Sad
The problem could be in other place, like in ReportEngine code??
private void showReport(String pAnswers) {
IReportEngine engine = null;
EngineConfig config = null;
IReportRunnable design = null;
onfig = new EngineConfig();
	try {
		Platform.startup(config);
		IReportEngineFactory factory = (IReportEngineFactory) Platform
		.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
		engine = factory.createReportEngine(config);
		design = engine
					.openReportDesign("C:/Documents and Settings/Administrator/workspace/EFY/src/com/arroba/reports/test.rptdesign");
		IRunAndRenderTask task = engine.createRunAndRenderTask(design);
		PDFRenderOption options = new PDFRenderOption();
		options.setOutputFormat(PDFRenderOption.OUTPUT_FORMAT_PDF);
		DateFormat dateFormat = new SimpleDateFormat("dd-MM-yyyy");
		Date date = new Date();
		options.setOutputFileName("C:/report.pdf");
		options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
		options.setOutputFormat("pdf");
		task.setRenderOption(options);
		task.setParameterValue("rpName", patient.getName());
		task.setParameterValue("rpLastName", patient.getLastName());
		task.setParameterValue("rpAge", patient.getAge());
		task.setParameterValue("rpAnswers", pAnswers);
		task.run();
		task.close();
		engine.destroy();
	} catch (Exception ex) {
		ex.printStackTrace();
	} finally {
		Platform.shutdown();
Re: Chart incomplete in PDF [message #801101 is a reply to message #801031] Fri, 17 February 2012 17:59 Go to previous messageGo to next message
Can you post the pdf output from the sample I sent you?
Jason
On 2/17/2012 3:50 PM, Leticia Simental wrote:
> Same result... :(
> try {
> design = engine
> task.run();
> task.close();
> engine.destroy();
> } finally {
Re: Chart incomplete in PDF [message #801106 is a reply to message #801101] Fri, 17 February 2012 18:12 Go to previous messageGo to next message
Sure, here:
  • Attachment: report.pdf
    (Size: 10.18KB, Downloaded 247 times)
Re: Chart incomplete in PDF [message #801222 is a reply to message #801106] Fri, 17 February 2012 22:31 Go to previous messageGo to next message
Try this code (My output is attached):
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EXCELRenderOption;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.RenderOption;
import org.eclipse.birt.report.engine.api.impl.RunAndRenderTask;
import org.eclipse.birt.report.engine.api.script.IReportContext;
public class RunAnRender {
public void runReport() throws EngineException
RunAndRenderTask task=null;
IReportEngine engine=null;
try{
config = new EngineConfig( );
config.setLogConfig("/tmp/dwn", Level.SEVERE);
Platform.startup( config );
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
//Open the report design
design = engine.openReportDesign("Reports/testpdf.rptdesign");
task = (RunAndRenderTask) engine.createRunAndRenderTask(design);
IReportContext irc = task.getReportContext();
//task.setParameterValue("Top Count", (new Integer(5)));
//task.validateParameters();
//HTMLRenderOption options = new HTMLRenderOption();
//options.setImageDirectory("./");
//options.setOutputFileName("output/resample/external.html");
//options.setOutputFormat("html");
//options.setEmbeddable(false);
//options.setEnableMetadata(true);
//options.setEnableInlineStyle(false);
//options.setEnableAgentStyleEngine(true);
//options.setEnableCompactMode(true);
options.setOutputFileName("output/resample/testpdf.pdf");
//EXCELRenderOption options = new EXCELRenderOption();
//options.setOutputFormat("xls");
//options.setOutputFileName("output/resample/customers.xls");
//options.setWrappingText(true);
//options.setImageHandler(new HTMLServerImageHandler());
//options.setSupportedImageFormats("JPG;PNG;BMP;SVG;GIF");
//options.setOutputFileName("output/external6.doc");
//options.setOutputFormat("doc");
//options.setOutputFormat("ppt");
//options.setOutputFileName("output/resample/ppttest.ppt");
//options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
task.run();
task.close();
engine.destroy();
}catch( Exception ex){
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAnRender ex = new RunAnRender( );
ex.runReport();
System.exit(0);
catch ( Exception e )
e.printStackTrace();
Jason
On 2/17/2012 6:12 PM, Leticia Simental wrote:
> Sure, here:
  • Attachment: testpdf.pdf
    (Size: 13.09KB, Downloaded 308 times)
Re: Chart incomplete in PDF [message #803061 is a reply to message #801222] Mon, 20 February 2012 16:58 Go to previous message
Hi Jason
It works!!! Very Happy
I guess i have some errors in my project...
i will check and let you know
Thanks a lot!
Previous Topic:Erroneous Handlers - BIRT 3.7.1
Next Topic:Setting jdbc fetch size for dataset
Current Time: Sat Jul 26 10:47:38 EDT 2025
Powered by FUDForum. Page generated in 0.37532 seconds
