Home » Eclipse Projects » Eclipse Platform » Custom editor content assist tab behavior
Custom editor content assist tab behavior [message #779947] Mon, 16 January 2012 16:56 Go to next message
Hello, I've been dinking around with making a custom editor for a few days, primarily going off the Java Editor example and am trying to put the finishing touches on.
One of my completion processors is based on Templates, and I can't figure out how to enable tab highlighting after entry.
For example, typing method =>
[public] [void] [methodName]([paramlist]) {
//TODO implement
[functionbody]
where it highlights public first and then on a tab highlights the next phrase in brackets, and so on.
I managed to find the Java Editor that Eclipse uses but when I looked at that it didn't even seem to be using the same org.eclipse.jface.text.contentassist constructs.
I overrode an implementation of ICompletionProposal.getSelection and can use that to select the first word I want, but don't know where to go from there.
Any suggestions?
Re: Custom editor content assist tab behavior [message #780506 is a reply to message #779947] Wed, 18 January 2012 06:09 Go to previous messageGo to next message
> //TODO implement [functionbody]
Are you talking about the highlighting once the template/code is
inserted? If so, what you want to look at is the linked mode UI. Take a
closer look at
org.eclipse.jdt.internal.ui.text.template.contentassist.TemplateProposal.apply(ITextViewer,
char, int, int).
Dani
> go from there.
> Any suggestions?
Re: Custom editor content assist tab behavior [message #780624 is a reply to message #780506] Wed, 18 January 2012 14:55 Go to previous message
Thanks Dani, that should be enough to figure it out.
Previous Topic:TabDescriptorProvider and tabbed.propertyTabs extension point
Next Topic:SWT: try to hide/show widgets without success
Current Time: Sat Jul 26 12:05:59 EDT 2025
Powered by FUDForum. Page generated in 0.04774 seconds
