Home » Eclipse Projects » Eclipse Platform » Adding jars to a bundle's classpath
| Adding jars to a bundle's classpath [message #538887] |
Tue, 08 June 2010 18:42   |
Eclipse User  |
I have a pretty specific problem that may or may not have a solution. I need to
use some third-party jars in my plug-in. I know that the typical way of doing
this is to just wrap the jars into their own plug-in and depend on it. But due
to licensing and installation problems (the tools that I'm using also have their
own install process because they depend on some custom environment variables), I
can't do that. Is there any way that I can get my plug-in to search for the jars
that I'm looking for and add them to the classpath? Thanks.
Del
| Re: Adding jars to a bundle's classpath [message #539039 is a reply to message #538894] |
Wed, 09 June 2010 08:15    |
Eclipse User  |
Del Myers wrote:
> I'm writing this stuff as a plug-in for Eclipse, so I don't really want
> to muck with the RCP classpath. The other problem is that my plug-in
> won't know about the third party jars until after it starts to run. It
> has to run to look for them, and the user may have installed them
> anywhere so it might come down to the user manually entering the
> location of the jars if all else fails. Do you suggest that I
> programatically edit the manifest and save it with the location of the
> external jars held in there and then tell the user to restart Eclipse?
> I'm not 100% sure how the bundle start-up process works. I imagine that
> the manifest is loaded before the bundle starts, in which case I would
> have to have the LIB_LOCATION environment variable set before Eclipse
> starts, and I'm not keen on editing environment variables. Doing
> anything to change the Eclipse start up process is not ideal. So
> manually entering the actual directory location in the manifest might be
> better.
Trying to edit a deployed manifest is not reliable.  It might be a jar,
and more importantly it might be in a read-only location.
If you supply external:$LIB_LOCATION$/useful.jar then the user can
supply -DLIB_LOCATION=/path/to/lib/folder ... either on the command line:
eclipse -vmargs -DIB_LOCATION=/path/to/lib/folder
or by editing the eclipse.ini and adding it after the -vmargs argument:
Potentially another option.  Start up your plugin (or a 3rd party lib
finder plugin), and have the user enter the library location.  Generate
a bundle into your state location with the correct MANIFEST.MF to
represent the jars in that location, and then use OSGi to install and
start that bundle.
Now you have a Bundle object and you can use loadClass(*) to access it.
  Or if your main bundle starts later, it can now see that bundle.
See org.osgi.framework.Bundle.start(int),
org.osgi.framework.BundleContext.installBundle(String, InputStream),
 org.osgi.service.packageadmin.PackageAdmin.refreshPackages(B undle[])
TestInstallUtil uses this to install test bundles into the running eclipse:
 http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ui.test s/Eclipse%20UI%20Tests/org/eclipse/ui/tests/dynamicplugins/T estInstallUtil.java?view=co
PW
Paul Webster
 http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
| Re: Adding jars to a bundle's classpath [message #539141 is a reply to message #539039] |
Wed, 09 June 2010 14:00    |
Eclipse User  |
Thank you very much. This gives me some ideas. The problem remains, though, that
I would need my "Application Code" bundle to depend on my "3rd Party Jars"
bundle in order for it to gain access to the classes that I need. Otherwise
Eclipse and p2 won't let my plug-in install (unsatisfied dependencies). Should I
supply a dummy bundle that pretends to supply the packages? Then on start-up, I
could look for the right location of the jars, generate a new new bundle with
the same id as the "3rd Part Jars" bundle but with a new version, stop the old
bundle, install the new one, and then start it. But, if the old bundle is in a
read-only location how can I be guaranteed to be able to install the new bundle?
That all seems very convoluted and fragile to be honest. I wish that there were
just some way to add the library location to the classloader as you are able to
with URL class loaders.
Asking the user to edit the eclipse.ini, or add a -D.... to their command line
is too much. You can't really expect users to do any of that--you can't even
expect programmers to do that. My experience is that if a feature doesn't work
out-of-the-box, then people won't use it. There can't be an install barrier.
Thank you very much for all your help so far.
Del
On 09/06/2010 5:15 AM, Paul Webster wrote:
>> want to muck with the RCP classpath. The other problem is that my
>> plug-in won't know about the third party jars until after it starts to
>> run. It has to run to look for them, and the user may have installed
>> them anywhere so it might come down to the user manually entering the
>> that the manifest is loaded before the bundle starts, in which case I
>> would have to have the LIB_LOCATION environment variable set before
>> Eclipse starts, and I'm not keen on editing environment variables.
>> Doing anything to change the Eclipse start up process is not ideal. So
>> be better.
> finder plugin), and have the user enter the library location. Generate a
> start that bundle.
> PW
| Re: Adding jars to a bundle's classpath [message #539149 is a reply to message #539141] |
Wed, 09 June 2010 15:02    |
Eclipse User  |
> though, that I would need my "Application Code" bundle to depend on my
> "3rd Party Jars" bundle in order for it to gain access to the classes
> that I need. Otherwise Eclipse and p2 won't let my plug-in install
> (unsatisfied dependencies). Should I supply a dummy bundle that pretends
> to supply the packages? Then on start-up, I could look for the right
> location of the jars, generate a new new bundle with the same id as the
> "3rd Part Jars" bundle but with a new version, stop the old bundle,
> bundle?
Well, that's different.  Adding it to a classloader on the fly means
only using reflection.  If you want to have real code ...
If you make the Require-Bundle optional and provide one during compile,
your compile will work.  If the requirement is optional, then you should
be able to install even if it is not already in their environment.  You
just have to make sure your "import 3rd party jar" plugin runs before
any code in your plugin tries to load one of the 3rd party classes.
That means ensure your real plugin will never start until later in the
cycle, or using tricks to keep initial code and code that uses the 3rd
party libs separate.
You can still create a URLClassLoader off of your plugin class loader
and load the jar ... you just need to use reflection or common
interfaces to interact with it.
Something like http://www.eclipse.org/datatools/ must do something
similar, as you must be able to tell it about JDBC connectors after the
datatools plugins are running.  Although this situation is most like the
URLClassLoader one, as their code interacts with a common set of
interfaces that are available by default.
less useful:  There is a p2 equivalent of install handlers called
touchpoints.  If you can write your update in terms of touchpoints then
as part of installing your plugins the system should be able to  set a
property in the configuration and/or eclipse.ini as part of your
touchpoint, never having to bother the users.  In theory if you could
write you own touchpoint then you could ask your users during an install
.... but I don't believe you can create your own touchpoints yet :-)
 http://wiki.eclipse.org/Equinox/p2/Engine/Touchpoint_Instruc tions
> there were just some way to add the library location to the classloader
> as you are able to with URL class loaders.
Actually, it's very stable and locked down ... the way enterprise
application like it.  The ability for code to bootstrap extra libs and
just run them is the double-edged sword ... flexibility, but if there's
a problem in the system, well, it's got some untested version of the
library in there so there's a lot of debugging goin' on :-)
> command line is too much. You can't really expect users to do any of
> that--you can't even expect programmers to do that. My experience is
> that if a feature doesn't work out-of-the-box, then people won't use it.
There is a usability problem with it, but it's not just the the bundles
but the licenses and your particular distribution.  From your usecase I
gather you're not distributing a product, but simply a plugin for
eclipse that depends on 3rd party libraries you can't distribute.
A product can control its eclipse.ini, and the installer can set up
anything (not uncommon for all apps), including asking the user to enter
the lib location during install and updating the file for them.  That
removes some of the usability concerns as it all had to be done up front.
You could pay for the appropriate license to distribute the libraries
you need, removing the problem all together ... but if you're providing
an open source plugin, that's also not a good solution :-)  Or they may
be GPLed code which you probably wouldn't be able to get commercial
licenses for anyway (some projects are dual licensed ... but not many).
I hope it goes well.
Paul Webster
| Re: Adding jars to a bundle's classpath [message #539151 is a reply to message #539141] |
Wed, 09 June 2010 15:05    |
Eclipse User  |
On further investigation, none of this seems to work. My plug-ins will not build
when I use Bundle-ClassPath: external:.... It seems that Eclipse won't look for
them at all during the build regardless of whether I use environment variables
or absolute paths. It simply will not find the external jars. Any ideas?
> bundle?
> Del
>>> be better.
>> start that bundle.
>> eclipse:
>> PW
| Re: Adding jars to a bundle's classpath [message #699104 is a reply to message #539179] |
Wed, 20 July 2011 16:34    |
Eclipse User  |
Was there a resolution to this problem?
In my development workspace in Eclipse, I'm pointing to a target platform that has plugins that specify the Bundle Classpath with 3rd party jars using the "external" keyword like so:
 external:$library.home$/lib/foo.jar,
 external:$library.home$/lib/bar.jar
I have plugin projects with Java code that uses classes located in the 3rd party jars.  My workspace's PDE build is unable to resolve these classes, so the build fails and I am unable to launch or debug the Eclipse application. I tried adding a -Dlibrary.home=... location in my dev Eclipse's eclipse.ini, but that didn't help.  I can't find a way to specifiy the "library.home" variable so the jars can be found and the classes resolved.
I can run the code in my plugins if I build the plugin projects from the command line using the PDE Ant Runner, edit the eclipse.ini to specify the -Dlibrary.home=... location, then launch the target platform's eclipse.exe.  The "external" jars and "library.home" variable all get resolved properly and everything works like it should.
So the problem is that I can't really do proper development, since my development workspace is basically unusable due to the compile errors.  I'd prefer not to set the "Extra Classpath Entries" on the Build tab of each plugin or add External JARs to the Libraries tab of the Java Build Path for each plugin project.  I have hundreds of external JARs, and about 50 plugins, so it's not really feasible to maintain a list of jars in my plugins' MANIFEST.MF files and then also in the plugins/projects build metadata. All of the information is available (external jars specified in the MANIFEST.MF and library.home value specified in the environment variables), so I'm hoping there is a way to get all of this working.
Thanks for any help,
Nadeem
Del Myers wrote on Wed, 09 June 2010 17:22It doesn't compile.
I did as you said: create a plugin project with a manifest and use
external:/path/to/lib/userful.jar for where it is installed in my system. The
PDE doesn't seem to recognize the "external" modifier, though.
I was able to get it to compile by using the Build tab of the PDE editor, but I
had to create another "Library" plug-in that had a linked folder to the library
location before the PDE would let me add the jars. It seems that there should be
another way of doing it, and I am just missing it.
Del
| Re: Adding jars to a bundle's classpath [message #780361 is a reply to message #699104] |
Tue, 17 January 2012 12:00   |
Eclipse User  |
I more or less had exactly the same problem and background as Del in the
original posting back in 2010. With the help of this thread I get it
working this way:
* use the way proposed by Paul, i.e. external classpath entries in the
Manifest
* for PDE build use a library bundle that is only referenced optional
and will not go into the final product
* in startup code of my bundle I check for the existence of the library
bundle, in case it's not there I further check for certain preferences
that do locate the libraries to include, if they are not there, nothing
is done and classes are not loaded (user is typically informed that he
has to configure things)
* a special preferences page lets the user enter the file locations and
forces a workbench restart
* on next startup the preferences are set and I install a fragment on
the fly
That seems to be an adequate solution, at least for me and our build and
development process.
However, I face only one issue: when forcing a restart, the bundle is
resumed after restart at an very early stage (more or less before my
application is started and can ask for a workspace). However, since my
code that creates the fragment on the fly relies on preferences, a
workspace is needed at that early stage which forces the default
workspace ;-(
Any idea? I remember that Paul wrote about exactly that "resume" issue
and that I would have to do something during shutdown what I cannot find
it anymore.
Jan
> classes resolved.
> working.
> Nadeem
>> It doesn't compile.
>> system. The PDE doesn't seem to recognize the "external" modifier,
>> though.
>> editor, but I had to create another "Library" plug-in that had a
>> linked folder to the library location before the PDE would let me add
>> the jars. It seems that there should be another way of doing it, and I
>> am just missing it.
>> Del
 Current Time: Mon Nov 03 20:37:16 EST 2025
 Powered by  FUDForum. Page generated in 0.05622 seconds
