Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Del-accelerator conflicts with del-"action" in text field
Del-accelerator conflicts with del-"action" in text field [message #778591] Fri, 13 January 2012 07:53 Go to next message
In the following sample, a shell is displayed with a text input field and a button. The menu contains a menu item with the accelerator <Del>. Unfortunately, the menu item is also invoked if the user pressed the del key in the input field. How to prevent that?
import org.eclipse.swt.*;
import org.eclipse.swt.events.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
public class DelKeyTest {
		final Display display = new Display();
		final Shell shell = new Shell(display, SWT.SHELL_TRIM);
		final Menu menuBar = new Menu(shell, SWT.BAR);
		shell.setMenuBar(menuBar);
		final Menu fileMenu = new Menu(menuBar);
		final MenuItem fileMenuItem = new MenuItem(menuBar, SWT.CASCADE);
		fileMenuItem.setText("&File");
		fileMenuItem.setMenu(fileMenu);
		final MenuItem delItem = new MenuItem(fileMenu, SWT.PUSH);
		delItem.setText("Delete\tDel");
		delItem.setAccelerator(SWT.DEL);
		delItem.addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(SelectionEvent e) {
				System.out.println("Menu item selected");
		shell.setLayout(new FillLayout());
		final Text textField = new Text(shell, SWT.SINGLE | SWT.BORDER);
		textField.setText("ab");
		textField.setSelection(1);
		new Button(shell, SWT.PUSH).setText("Here Del should invoke the menu item");
		shell.pack();
		shell.setMinimumSize(shell.getSize());
		shell.open();
		while (!shell.isDisposed()) {
			if (!display.readAndDispatch()) {
				display.sleep();
		display.dispose();
Thanks in advance.
Thomas
Re: Del-accelerator conflicts with del-"action" in text field [message #778615 is a reply to message #778591] Fri, 13 January 2012 09:14 Go to previous messageGo to next message
I think the existing behavior is as expected.
To prevent the menuitem from being selected, you could disable it when the focus is in the input field.
But, in this case, since the delete action is valid in the input field, you could probably implement a delete action for the input field and call it on menu item's selection.
Re: Del-accelerator conflicts with del-"action" in text field [message #778625 is a reply to message #778615] Fri, 13 January 2012 10:03 Go to previous message
Thank you for your feed-back.
Lakshmi Shanmugam wrote on Fri, 13 January 2012 09:14
I would not expect it. I would expect that the focused component could handle the key first, then all parent controls and if it was not processed, then the accelerator would be used. At least that's how Swing did it.
That would be VERY hard in our application, because the menu item (aka its belonging action) does not (and should not) know anything about input fields or a focused control.
The delete key was just a sample. The user of our application is free to change the accelerators to their needs. Hence similar conflicts may happen for any key which is used by input fields.
Thomas
Previous Topic:Embedded ant versus external ant
Next Topic:Drag & Drop table - dragging items down past window too slow
Current Time: Thu Jul 24 11:22:00 EDT 2025
Powered by FUDForum. Page generated in 0.04441 seconds
