Home » Archived » Buckminster » Setting up additional remotes for GIT repository
Setting up additional remotes for GIT repository [message #778324] Thu, 12 January 2012 06:53 Go to next message
I am currently evaluating the options for us moving from a setup with subversion as CMS to a combination of git and gerrit. The setup work fine also including buckminster to provision my workspace, only one whish left:
Is it possible to define in my RMAP to create additional remotes for the repository? The only references I found regarding remotes are the two parameters git.remote.uri and git.remote.name. But I can't figure out how to use thme to define more than one remote for the new repository.
Having a feature like this would make it possible to use buckminster for setup of different users workspaces without any manual rework afterwards.
Alexander
Re: Setting up additional remotes for GIT repository [message #778459 is a reply to message #778324] Thu, 12 January 2012 08:14 Go to previous messageGo to next message
Just to check that I understand your question. Do you want Buckminster
to configure the local git clone so it has knowledge of more than a
single remote git repository?
This is not something Buckminster can do at the moment. I can think of a
lot of things you may want to specify/do with the clone when configuring
- such as specifying how much history, which branches to fetch, creating
tracking branches etc.
Don't know if we have any issues logged that covers this. Thomas?
- henrik
On 2012-12-01 12:53, Alexander May wrote:
> whish left:
> Alexander
Re: Setting up additional remotes for GIT repository [message #778460 is a reply to message #778459] Thu, 12 January 2012 08:50 Go to previous messageGo to next message
No, no issues so please enter one for this. Can't
- thomas
Re: Setting up additional remotes for GIT repository [message #778461 is a reply to message #778460] Thu, 12 January 2012 08:53 Go to previous messageGo to next message
Oops. Didn't mean to post with an incomplete last sentence. What I meant
to write was:
Can't make any promises about priority for this since I think the need
for this particular function is limited. An attached functional patch
will of course increase the chance of getting it in significantly :-)
- thomas
> - thomas
Re: Setting up additional remotes for GIT repository [message #778550 is a reply to message #778461] Fri, 13 January 2012 03:32 Go to previous messageGo to next message
Right, Henrik, thats exactly what I want to do. For us currently only the option of adding different remotes is interesting, as this is something that should be the same for all developers (at least for some remotes, such as our gerrit server). Anyhow one should keep those other options in mind for further improvements.
I will create an issue for that when we are sure that we stick to this solution and then are really interested in this feature. Untill now I'm just investigating and don't want to create too much work for anyone that we maybe never use lateron.
Anyhow, do you have any suggestions where to start looking for such improvemnts, as you are the guys who know the buckminster code much better than me.
Alexander
Re: Setting up additional remotes for GIT repository [message #778959 is a reply to message #778550] Sat, 14 January 2012 03:19 Go to previous message
> better than me.
I would start here:
http://git.eclipse.org/c/buckminster/buckminster.git/plain/org.eclipse.buckminster.git/src/org/eclipse/buckminster/git/internal/RepositoryAccess.java
The cloning takes place in the method getRepository() and I guess adding
things to the remote configuration must take place right after that.
Thomas Hallgren
Previous Topic:Import via MSPEC via HTTP
Next Topic:/usr/bin/sign on a windows machine
Current Time: Sun Jul 27 11:16:38 EDT 2025
Powered by FUDForum. Page generated in 0.04827 seconds
