Home » Archived » BIRT » Text Overflow to another cell(Text Overflow)
Text Overflow to another cell [message #653148] Tue, 08 February 2011 11:44 Go to next message
I am using BIRT 2.6.1 Report API. I am building some Human Resource type forms that are pre-populated with as much data as possible. In this form I have a block that is filled will a mangers notes about a person. The problem I am having is on occasion the notes are 50 -> 100 lines of text and the block of the form is only so big. The last page of this form is a continuation page of that block "Manager's Notes (continued)".
Is there a way I can get a Data element in a cell to overflow to another specific cell? Also, pending the size of the data to generate more contiuation pages?
I am assuming I set the continuation page as a master page, but I dont know how to get the data to overflow onto the new pages.
Right now the text is in a Grid > Row > Cell > Data[COLUMN_NAME]
This is the result of an expression that just scripts a little bit of formatting.
Thanks for any help.
Re: Text Overflow to another cell [message #653223 is a reply to message #653148] Tue, 08 February 2011 16:22 Go to previous messageGo to next message
I have not tried this but if you know the length that will fit could you
do a substring on the data in the first page and add another data item
after the first grid that holds the remainder string?
Jason
On 2/8/2011 11:44 AM, NerdyJoe wrote:
> Hello,
> contiuation pages?
> formatting.
Re: Text Overflow to another cell [message #778077 is a reply to message #653223] Wed, 11 January 2012 06:35 Go to previous messageGo to next message
Jason Weathersby wrote on Tue, 08 February 2011 16:22
Jason
Is there any other way for this ??? without using the substring .....
Re: Text Overflow to another cell [message #778404 is a reply to message #778077] Wed, 11 January 2012 13:32 Go to previous message
I do not know of one.
Jason
>> you do a substring on the data in the first page and add another data
>> item after the first grid that holds the remainder string?
>> Jason
Previous Topic:getting Data Element value in onCreate event
Next Topic:Birt Language Packs
Current Time: Thu Jul 24 21:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.26406 seconds
