Home » Eclipse Projects » Rich Client Platform (RCP) » Can't have a button labeled "Stop"?
Can't have a button labeled "Stop"? [message #777172] |
Mon, 09 January 2012 20:01  |
I have a dialog with several buttons.
One of them has the text "Stop". Or I should stay I'd LIKE to have the button text be "Stop".
I can't.
If I set the button text to "Stop" - the button doesn't show up when the dialog is displayed.
If I change the text to something else, it does show up.
Huh?
Re: Can't have a button labeled "Stop"? [message #778261 is a reply to message #778035] |
Wed, 11 January 2012 21:56   |
This is in a jface dialog.
Whenever I set the button text to "Stop", it would never be displayed in the dialog.
mcomposite_5 = new Composite(mcompImportStatus, SWT.NONE);
mcomposite_5.setLayout(new FillLayout(SWT.VERTICAL));
mcomposite_5.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false, true, 1, 1));
mcomposite_5.setSize(43, 55);
mbtnStop = new Button(mcomposite_5, SWT.NONE);
mbtnStop.setEnabled(false);
mbtnStop.setText("Stop Import");
mbtnStop.addSelectionListener(new SelectionAdapter() {
public void widgetSelected( SelectionEvent e) {
if (mImporter != null) {
mImporter.stop();
} else if (mFolderCreator != null) {
mFolderCreator.stopCreating();
return;
Re: Can't have a button labeled "Stop"? [message #778392 is a reply to message #778318] |
Thu, 12 January 2012 13:18  |
Doing the setBounds() didn't make any difference.
The other button in the Composite shows up just fine. (It's the 2nd control)
I noticed that it had a mbtnPause.setSize(43,25) call.
So I commented that out.
Now NEITHER button shows up.
Added the setSize() to the mbtnStop (only, didn't uncomment the other)
Now just the Stop button shows up.
uncommented the other, so both buttons have it.
Still, only the Stop button is being displayed.
Tried making the sizes larger or smaller. No change.
So, I removed the .setSize() call from both buttons, and changed the text of the mbtnStop to be "Stop Import".
Now both buttons show up just fine.
This is bizarre.
So, here is the entire "createDialogArea()" method.
protected Control createDialogArea( Composite parent) {
Composite container = (Composite) super.createDialogArea(parent);
mtabFolder = new TabFolder(container, SWT.NONE);
mtabFolder.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true, 1, 1));
mtabMBox = new TabItem(mtabFolder, SWT.NONE);
mtabMBox.setText("Mbox");
mCurTab = mtabMBox;
mcompMbox = new Composite(mtabFolder, SWT.NONE);
mtabMBox.setControl(mcompMbox);
mcompMbox.setLayout(new GridLayout(3, false));
Label lblMboxPath = new Label(mcompMbox, SWT.NONE);
lblMboxPath.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, false, false, 1, 1));
lblMboxPath.setSize(60, 15);
lblMboxPath.setText("mbox Path:");
mtxtPath = new Text(mcompMbox, SWT.BORDER);
mtxtPath.addFocusListener(new FocusAdapter() {
public void focusLost( FocusEvent e) {
checkButtonState();
return;
mtxtPath.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mtxtPath.setSize(277, 21);
Button btnBrowse = new Button(mcompMbox, SWT.NONE);
btnBrowse.setSize(50, 25);
btnBrowse.addSelectionListener(new SelectionAdapter() {
Shell shell = new Shell(Display.getDefault(), SWT.APPLICATION_MODAL);
FileDialog dialog = new FileDialog(shell);
dialog.setText("Select mbox file");
dialog.setFileName(mtxtPath.getText());
String file = dialog.open();
if (file != null) {
mtxtPath.setText(file);
checkButtonState();
return;
btnBrowse.setText("Browse");
Label lblTargetFolder = new Label(mcompMbox, SWT.NONE);
lblTargetFolder.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, false, false, 1, 1));
lblTargetFolder.setSize(73, 15);
lblTargetFolder.setText("Target Folder:");
mbuttonSelFolder = new Button(mcompMbox, SWT.NONE);
mbuttonSelFolder.addSelectionListener(new SelectionAdapter() {
try {
FolderSelectDialog dialog = new FolderSelectDialog(getShell());
dialog.open();
mFolderID = dialog.getSelectedFolder();
mbuttonSelFolder.setText((mFolderID == 0) ? "<select folder>" : getFolder(mFolderID).getName());
} catch (RemoteException ex) {
logger.error("Remote Exception", ex);
} catch (FolderNotFoundException ex) {
logger.error("Folder Not Found Exception", ex);
checkButtonState();
return;
mbuttonSelFolder.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mbuttonSelFolder.setText("<select folder>");
Label lblAccountIfNo = new Label(mcompMbox, SWT.NONE);
lblAccountIfNo.setToolTipText("Accoun to use if Import is unable to guess an Account for a message.");
lblAccountIfNo.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, false, false, 1, 1));
lblAccountIfNo.setSize(147, 15);
lblAccountIfNo.setText("Default Account:");
mcmbAccounts = new Combo(mcompMbox, SWT.READ_ONLY);
mcmbAccounts.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mcmbAccounts.setSize(277, 23);
mcmbAccounts.addSelectionListener(new SelectionAdapter() {
int selid = mcmbAccounts.getSelectionIndex();
if (selid != -1) {
mAccountID = ((IAccount) mcmbAccounts.getData(mcmbAccounts.getItem(selid))).getID();
} else {
mAccountID = 0;
checkButtonState();
return;
mbtnMarkUnread = new Button(mcompMbox, SWT.CHECK);
mbtnMarkUnread.setSize(157, 16);
mbtnMarkUnread.setText("Mark messages as Unread");
mtabTB = new TabItem(mtabFolder, SWT.NONE);
mtabTB.setText("Thunderbird");
mcompTBird = new Composite(mtabFolder, SWT.NONE);
mtabTB.setControl(mcompTBird);
mcompTBird.setLayout(new GridLayout(3, false));
mlabel_3 = new Label(mcompTBird, SWT.NONE);
mlabel_3.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, false, false, 1, 1));
mlabel_3.setText("Profile Directory:");
mtextProfileDir = new Text(mcompTBird, SWT.BORDER);
mtextProfileDir.addFocusListener(new FocusAdapter() {
checkButtonState();
return;
mtextProfileDir.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mbuttonProfileBrowse = new Button(mcompTBird, SWT.NONE);
mbuttonProfileBrowse.addSelectionListener(new SelectionAdapter() {
DirectoryDialog dialog = new DirectoryDialog(shell);
dialog.setText("Select Thunderbird Profile Directory");
if (file != null) {
mtextProfileDir.setText(file);
checkButtonState();
return;
mbuttonProfileBrowse.setText("Browse");
mbuttonTBFindAccts = new Button(mcompTBird, SWT.NONE);
mbuttonTBFindAccts.addSelectionListener(new SelectionAdapter() {
tbirdScan();
checkButtonState();
return;
mbuttonTBFindAccts.setText("Find Accounts");
mlabel_4 = new Label(mcompTBird, SWT.NONE);
mlabel_4.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, false, false, 1, 1));
mlabel_4.setText("Accounts:");
mcomposite_4 = new Composite(mcompTBird, SWT.NONE);
mcomposite_4.setLayout(new FillLayout(SWT.VERTICAL));
mcomposite_4.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true, 2, 2));
mtvTBAccounts = CheckboxTableViewer.newCheckList(mcomposite_4, SWT.BORDER | SWT.FULL_SELECTION);
mtableTBAccounts = mtvTBAccounts.getTable();
mtvTBFolders = CheckboxTableViewer.newCheckList(mcomposite_4, SWT.BORDER | SWT.FULL_SELECTION | SWT.MULTI);
mtableTBFolders = mtvTBFolders.getTable();
mtvTBFolders.addCheckStateListener(new ICheckStateListener() {
public void checkStateChanged( CheckStateChangedEvent event) {
IStructuredSelection sel = (IStructuredSelection) mtvTBFolders.getSelection();
Object[] elements = sel.toArray();
for (int idx = 0; (idx < elements.length); idx++) {
mtvTBFolders.setChecked(elements[idx], event.getChecked());
return;
mlabel_5 = new Label(mcompTBird, SWT.NONE);
mlabel_5.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, false, false, 1, 1));
mlabel_5.setText("Folders:");
mcheckNoTrash = new Button(mcompTBird, SWT.CHECK);
mcheckNoTrash.setSelection(true);
mcheckNoTrash.setText("Don't Import TRASH folders");
mlabel_6 = new Label(mcompTBird, SWT.NONE);
mlabel_6.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, false, false, 1, 1));
mlabel_6.setText("Default Account:");
mcomboTBDefAcct = new Combo(mcompTBird, SWT.READ_ONLY);
mcomboTBDefAcct.addSelectionListener(new SelectionAdapter() {
int selid = mcomboTBDefAcct.getSelectionIndex();
if (selid != -1) {
mAccountID = ((IAccount) mcomboTBDefAcct.getData(mcomboTBDefAcct.getItem(selid))).getID();
} else {
mAccountID = 0;
checkButtonState();
return;
mcomboTBDefAcct.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mcompImportStatus = new Composite(container, SWT.NONE);
mcompImportStatus.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mcompImportStatus.setLayout(new GridLayout(3, false));
Label lblStatus = new Label(mcompImportStatus, SWT.NONE);
lblStatus.setSize(35, 15);
lblStatus.setText("Status:");
mcomposite_1 = new Composite(mcompImportStatus, SWT.NONE);
mcomposite_1.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mcomposite_1.setSize(144, 55);
mcomposite_1.setLayout(new GridLayout(3, false));
mcomposite_2 = new Composite(mcomposite_1, SWT.NONE);
mcomposite_2.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mcomposite_2.setLayout(new GridLayout(1, false));
mlabel = new Label(mcomposite_2, SWT.CENTER);
mlabel.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mlabel.setSize(36, 15);
mlabel.setText("Count");
mlblCount = new Label(mcomposite_2, SWT.RIGHT);
mlblCount.setAlignment(SWT.CENTER);
mlblCount.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mlblCount.setSize(36, 15);
mlblCount.setText("0");
mcomposite_3 = new Composite(mcomposite_1, SWT.NONE);
mcomposite_3.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mcomposite_3.setLayout(new GridLayout(1, false));
mlabel_1 = new Label(mcomposite_3, SWT.CENTER);
mlabel_1.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mlabel_1.setText("Size");
lblSize = new Label(mcomposite_3, SWT.RIGHT);
lblSize.setAlignment(SWT.CENTER);
lblSize.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mcomposite = new Composite(mcomposite_1, SWT.NONE);
mcomposite.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mcomposite.setLayout(new GridLayout(1, false));
mlabel_2 = new Label(mcomposite, SWT.CENTER);
mlabel_2.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mlabel_2.setText("% Done");
mlblPctDon = new Label(mcomposite, SWT.RIGHT);
mlblPctDon.setAlignment(SWT.CENTER);
mlblPctDon.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
mlblPctDon.setText("0");
//mbtnStop.setSize(43,25);
mImporter.stop();
return;
mbtnPause = new Button(mcomposite_5, SWT.NONE);
mbtnPause.setEnabled(false);
//mbtnPause.setSize(43, 25);
mbtnPause.addSelectionListener(new SelectionAdapter() {
mImporter.pause(!mImporter.isPaused());
mbtnPause.setText(mImporter.isPaused() ? "Resume" : "Pause");
return;
mbtnPause.setText("Pause");
mlblMsg = new Label(mcompImportStatus, SWT.NONE);
mlblMsg.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 3, 1));
mlblMsg.setSize(18, 15);
mtabFolder.addSelectionListener(new SelectionAdapter() {
logger.debug("Changed Tab");
TabItem[] items = mtabFolder.getSelection();
if ((items.length > 0) && (items[0] == mtabMBox)) {
mCurTab = mtabMBox;
} else {
mCurTab = mtabTB;
checkButtonState();
return;
fillLists();
return container;
Current Time: Wed Jul 23 07:45:29 EDT 2025
Powered by FUDForum. Page generated in 0.07129 seconds
