Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Embedded ant versus external ant
Embedded ant versus external ant [message #778342] Thu, 12 January 2012 08:20 Go to next message
I'm working with Eclipse Indigo 3.7 SR1 (so I can use JDK 1.7).
Moreover, I installed ant 1.7.1, I use it till now to compile Orbacus 4.3.4 (Java version). I don't want to build Orbacus by means of Eclipse, I built it by using the build provided by Orbacus.
Indigo has a plugin, org.apache.ant_1.8.2.v20110505-1300: I guess it's the embedded ant used by Eclipse, when I run a build.xml file belonging to an Eclipse project.
And it corresponds to version 1.8.2 of ant.
My question: is there any procedure to make Eclipse use an external ant instead of the embedded one ?
Virgilio
Re: Embedded ant versus external ant [message #778592 is a reply to message #778342] Fri, 13 January 2012 08:05 Go to previous message
This is not the right forum for your question, you should probably ask this in the Eclipse Platform forum.
A quick google search gave me this --> http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.platform.doc.user%2Ftasks%2Ftasks-ant-version.htm
HTH!
Previous Topic:Windows 8 Support
Next Topic:Del-accelerator conflicts with del-"action" in text field
Current Time: Wed Jul 23 06:41:28 EDT 2025
Powered by FUDForum. Page generated in 0.04826 seconds
