AUT could not be started, because no valid Java JRE was specified [message #778253] |
Wed, 11 January 2012 19:24  |
I try to get my integration testing done when building the project with Jenkins/Hudson.
For that I am using the maven ant task plugin to execute the testexec application.
Everything works fine, the test suite is imported to the test db and when executing the test I get the error
[exec] Wed Jan 11 23:31:59 UTC 2012 AUT: Starting AUT: AUT MyApp
[exec] !!Error occurred !!
[exec] AUT could not be started, because no valid Java JRE was specified
[exec] Wed Jan 11 23:32:05 UTC 2012 AUT Agent: connection closed
[exec] Wed Jan 11 23:32:05 UTC 2012 Exit: Code 1
I tried to setup the JAVA_HOME variable on the hudson box but without success. Though the autagent is running and fine. Also tried to specify the -vm as AUT parameter pointing to the bin folder of the java installation but no luck.
Does anybody got an idea what could be the reason and how to fix that? It's a Linux box (32-bit) running a 32bit Java 6 (Sun/Oracle).
Thanks in advance,
Lars
Re: AUT could not be started, because no valid Java JRE was specified [message #784232 is a reply to message #783755] |
Fri, 27 January 2012 03:27  |
Thanks for your comments. Feel free to put in an enhancement for improved error messaging for the AUT start or for other aspects that seem to be missing.
In terms of your comment about the quality, again, if you find specific errors, please let us know by entering issues into Bugzilla and by all means contribute with patches as well.
Alex
FUDForum. Page generated in 0.03898 seconds
