Home » Language IDEs » ServerTools (WTP) » Can't start Tomcat
| Can't start Tomcat [message #77687] |
Sun, 27 February 2005 09:16  |
Originally posted by: fassev.gmx.de
I downloaded and installed the new M3 build of the WTP and created a new
Web Project as showed in the Tutorial "WTP Tutorials - Building a School
Schedule Web Application". Everything goes ok, except that I am not able
to start the Tomcat 5.0. I am getting Class not found Exceltion :
java.lang.NoClassDefFoundError: org/apache/catalina/startup/Bootstrap
Looking at the Tomcat v5.0 runtim configuration within my project, I do
not see the bootstrap.jar, commons-launcher.jar, commons-daemmon.jar - all
of them laying in the Tomcat5.0/bin directory.
What I am doing wrong?
Best Regards
Peter
| Re: Can't start Tomcat [message #78794 is a reply to message #78736] |
Tue, 01 March 2005 16:09   |
I was able to duplicate this. Drop the trailing '\' and just use
"E:\jakarta-tomcat-5.0.28" and it should work. The extra '\' causes the
launch configuration to contain "...\bin\" rather than
"...\bin\bootstrap.jar" in the classpath.
You can either delete and re-create the server, or execute Window ->
Preferences and select Server -> Installed Runtimes -> "your runtime"
and click Edit. Remove the trailing '\' from the installation directory
and save.
I'll see about logging a defect and providing a patch.
Larry
Muhammad Dwyer wrote:
> Hello Lawrence,
> My tomcat installation directory is E:\jakarta-tomcat-5.0.28\ - this is
> also how I entered it in the "Edit Server Runtime" dialog - otherwise
> eclipse won't let you get any further.
>> Hi Peter,
>> Are you specifying the root directory of you Tomcat install as the
>> install location? If so, what is the directory name? There was a post
>> above that suggested the directory name must be as creates it when you
>> unzip.
>> Lawrence
>>> Hello,
>>> new Web Project as showed in the Tutorial "WTP Tutorials - Building a
>>> School Schedule Web Application". Everything goes ok, except that I
>>> am not able to start the Tomcat 5.0. I am getting Class not found
>>> Exceltion :
>>> do not see the bootstrap.jar, commons-launcher.jar,
>> all
>>> Best Regards
>>> Peter
| Re: Can't start Tomcat [message #78824 is a reply to message #78794] |
Tue, 01 March 2005 16:31   |
Originally posted by: muhammad.dwyer.gmail.com
Dear Larry,
Thank you very much! I've now got my first JSP running on Tomcat under Eclipse!
I can now move onto some more serious stuff. Excellent, thanks again.
Kind regards,
Muhammad
> the launch configuration to contain "...\bin\" rather than
> directory and save.
> Cheers,
> Larry
>> Hello Lawrence,
>> is also how I entered it in the "Edit Server Runtime" dialog -
>> otherwise eclipse won't let you get any further.
>>> Hi Peter,
>>> post above that suggested the directory name must be as creates it
>>> when you unzip.
>>> Lawrence
>>>> Hello,
>>>> a new Web Project as showed in the Tutorial "WTP Tutorials -
>>>> Building a School Schedule Web Application". Everything goes ok,
>>>> except that I am not able to start the Tomcat 5.0. I am getting
>>>> I do not see the bootstrap.jar, commons-launcher.jar,
>>> all
>>>> Best Regards
>>>> Peter
| Re: Can't start Tomcat [message #79069 is a reply to message #78794] |
Wed, 02 March 2005 08:58   |
I've entered <https://bugs.eclipse.org/bugs/show_bug.cgi?id=86988> for
this bug.
Larry
> and save.
> Cheers,
> Larry
>> Hello Lawrence,
>>> Hi Peter,
>>> unzip.
>>> Lawrence
>>>> Hello,
>>>> Exceltion :
>>> all
>>>> Best Regards
>>>> Peter
| Re: Can't start Tomcat [message #79983 is a reply to message #79069] |
Thu, 03 March 2005 17:20  |
Hello Larry,
I've noticed that eclipse 3.1 (I was first working with 3.0.1) doesn't add
a backslah to the end of the server path by default, which makes life a little
easier :)
Muhammad
> this bug.
> Larry
>> directory and save.
>> Cheers,
>> Larry
>>> Hello Lawrence,
>>>> Hi Peter,
>>>> when you unzip.
>>>> Lawrence
>>>>> Hello,
>>>> all
>>>>> Best Regards
>>>>> Peter
Current Time: Thu Nov 06 10:56:19 EST 2025
Powered by FUDForum. Page generated in 0.04063 seconds
