Problem with context menus on MacOSX [message #777160] |
Mon, 09 January 2012 19:28  |
Ive been moving a testsuite designed on Windows over to test the mac version of our AUT and have run into some behavior I cant explain on MacOSX.
The test currently passes on windows in the current form:
<Select Project from Tree>
<ub_grc_selectContextMenuEntry_byTextpath>[TEXTPATH; OPERATOR; MOUSE_BUTTON]
<waitForWindow>
In the above case the data is the following respectively:
'Delete'
equals
3
This testcase is to open the delete dialog via the context menu of an eclipse project. Unfortunately this method does not work on Mac for some reason. It fails to open the "right-click" context menu. Using the recorder I have been playing around with context menus to find a way to make this work on both platforms but as it stands I cant even get it to work at all on Mac. The recorder spits out the following.
<Select Context Menu Entry by Textpath on Tree>
<wait for Window>
This first test case does not appear to be in the concrete modules at all so Im not sure where it came from but rerunning the recorded test fails also.
Right clicking a project in our Eclipse based AUT has the following options among others:
New >
Open in New Window
Copy
Paste
Delete
Move...
Rename...
Refresh...
Close Project...
Properties
Of these, only these four actually worked using the recorded test:
Open in New Window
Copy
Rename
Close/Open Project
The others "passed" the test case but failed to wait for window when the dialog never appeared. After discovering some do not work with the recorded test, I retried the <ub_grc_selectContextMenuEntry_byTextpath> test on the menu entries and it is exhibiting the same behavior. If anyone has experienced this before I would appreciate any comments.
FUDForum. Page generated in 0.30891 seconds
