Home » Language IDEs » PHP Development Tools (PDT) » mysql_connect undefined when running script from Eclipse(mysql_connect undefined when running script from Eclipse)
mysql_connect undefined when running script from Eclipse [message #777083] Mon, 09 January 2012 15:11 Go to next message
Hi there,
I am getting an error of mysql_connect function undefined when running a command line script for Eclipse, both on debugging or run mode (I have substituted the full path by ...):
PHP Fatal error: Call to undefined function mysql_connect() in .../mysql.inc.php on line 8
Executed directly from command line, the script works without this problem.
This is on an Ubuntu 11.10 box.
I have set on Preferences/PHP/PHP Executables the following parameters:
Executable path: /usr/bin/php
PHP ini file: /etc/php5/cli/php.ini
At first I did not included the ini file, but then I did to check if it solves the error without success.
Any hints?
Thanks a lot in advance,
Re: mysql_connect undefined when running script from Eclipse [message #777520 is a reply to message #777083] Tue, 10 January 2012 11:13 Go to previous messageGo to next message
> Any hints?
It seems that You are running configuration that have no needed module loaded.
Run phpinfo and review configuration and paths, that should give you enought
info to solve issue with mysql.
/dmc
Re: mysql_connect undefined when running script from Eclipse [message #778107 is a reply to message #777083] Wed, 11 January 2012 07:22 Go to previous messageGo to next message
It is a well-known/notorious issue...
FYI
Bug 339547 - add "Use system default php.ini configuration" in EXE prefs
Bug 347618 - Additional PHP .ini files not parsed
For eclipse PDT which php.ini is it picking up for PHP scripts - Stack Overflow
It is a bug of pdt.
Re: mysql_connect undefined when running script from Eclipse [message #778183 is a reply to message #777520] Wed, 11 January 2012 09:35 Go to previous messageGo to next message
Hi dominik,
If I run phpinfo() from within Eclipse, no mysql string is showed as expected: given the problem I have it is clear that within Eclipse there is no mysql support. But the question is why?.
Even when I explicitly set the same php.ini file that uses the cli php command on the same system and it does has mysql support.
Re: mysql_connect undefined when running script from Eclipse [message #778188 is a reply to message #778107] Wed, 11 January 2012 09:41 Go to previous message
Hi Toshihiro,
Interesting. I will try some of the workarounds exposed there.
Thanks a lot,
Previous Topic:How to connect to my local database server
Next Topic:'Open call hierarchy' (Ctrl-Alt-H) doesn't seem to work for me
Current Time: Fri Jul 25 22:53:33 EDT 2025
Powered by FUDForum. Page generated in 0.05847 seconds
