shared singleton synchronization [message #777386] |
Tue, 10 January 2012 06:45  |
Hello RAP users,
I have a collection that have to be shared across users of my RAP
application. The content of this collection is to be shown in a web page
through a tree viewer. Obviously, all users can access this collection
and also modify it. As this collection is a shared singleton, I have to
take care of concurrency problems.
I know only two solutions to this problem :
1) Duplicate entirely or partially the collection for each user session.
As this instance will be contained in only one user thread session,
there is no more synchronization problem, except when user want to apply
modification. In that case, any kind of synchronized or timed out lock
can do the job. But I need to regularly update all UI users : implies to
call setInput of tree viewer with a new synchronized updated instance of
the collection at regular interval. And what about memory allocation ?
2) Publish the collection outside of its container. In that case, I
Think I have to synchronize all my data model. The advantage is that all
UI users are updated with a simple call to refresh of the tree viewer.
What do you think about that ? What do you usually do ? Are there any
other solutions ?
Thanks a lot for your help,
frank
Re: shared singleton synchronization [message #782689 is a reply to message #777386] |
Tue, 24 January 2012 03:35  |
Hello Yuri and Ronald,
thanks alot for your responses.
And yes Yuri, you are absolutely right : this a general servlet topic
and perhaps an even more general one...
But I've not found a forum based on this kind of topic and as I'm
working with RAP and encounter this problem, I've thought that someone
could give some links...
thanks,
frank
FUDForum. Page generated in 0.05117 seconds
