Should an empty bin/ directory be checked in? [message #777310] |
Tue, 10 January 2012 04:08  |
Our Java projects (mostly plugins) use a fairly standard layout, with Java source in src/ (and sometimes test/) directories, which get compiled to a bin/ directory. Obviously, the source code, but not the compiled classes, get checked in to the repository.
Previously, we used subversion, and had svn:ignore set so that neither bin/ nor its contents were checked in to the respoitory. Hence there is no bin/ in the repository at all.
We're moving to Git, so I'm reviewing the way we do things. What's best:
(1) Don't have bin/ in the respository (specified by .gitignore in the project parent directory)
OR
(2) Check an empty bin/ in the respository (empty except for a .gitignore in the bin/ directory)
Is one way better than the other, or is it just a case of personal preference? I'm leaning towards (2).
Matthew
Re: Should an empty bin/ directory be checked in? [message #777320 is a reply to message #777310] |
Tue, 10 January 2012 04:16   |
You should add
/*/bin/
in order to avoid that some random 'bin' folder gets excluded. Storing
an empty 'bin' folder doesn't buy you anything.
Dani
> OR
> Thanks
> Matthew
Re: Should an empty bin/ directory be checked in? [message #779384 is a reply to message #778848] |
Sun, 15 January 2012 10:28  |
There's rarely any point in tracking only a .gitignore in any given directory. It really only makes sense if the directory meets two conditions: it must exist AND it isn't created automatically on demand. That's an unusual combination and definitely doesn't apply in the case you mention. Worse, as Robin points out, a standard clean operation will delete the directory, forcing you to restore the tracked .gitignore.
FUDForum. Page generated in 0.24429 seconds
