Home » Archived » BIRT » Reg: rptdesign files getting corrupted(rptdesign files getting corrupted)
Reg: rptdesign files getting corrupted [message #775722] Fri, 06 January 2012 10:33 Go to next message
We often make some changes to our rptdesign files and in this process observed that the file are getting corrupted. By corrupted i meant that, the changes we make are not getting reflected and the reports are not working as expected.
For ex: we display a report with all the cardholders and their transactions, we observed that after running the report for n number of times and making some changes to meet some business requirements, the rptdesign is corrupted and the column that displays cardholder names , is displaying only one name thru out the report in-spite of no logical error.
We had to redo the report to work as expected.
Is there any limitation on the number of time we generate reports using a rptdesign file.?Does rptdesign gets obsolete using it regularly.
FYI
We are using Birt3.7 version
App server:Web logic 10 in linux.
Jdk:1.5
Db:Oracle
Any help regarding this is appreciated.
KKP
[Updated on: Fri, 06 January 2012 10:45] by Moderator
Re: Reg: rptconfig files [message #775800 is a reply to message #775722] Fri, 06 January 2012 12:34 Go to previous messageGo to next message
No there is no limit. Does the report use parameters to cull the data?
Jason
On 1/6/2012 10:33 AM, kkp Mising name wrote:
> error.
> a rptdesign file.?
> KKP
Re: Reg: rptconfig files [message #776858 is a reply to message #775800] Mon, 09 January 2012 06:56 Go to previous messageGo to next message
Jason,
We don't filter on the data, all the data from query is taken as it is.So do you see any issue with report getting damaged or corrupted.
KKP
Re: Reg: rptconfig files [message #776977 is a reply to message #776858] Mon, 09 January 2012 10:54 Go to previous messageGo to next message
I have never seen one get corrupted in the scenario you describe. Is a
rptconfig file for the report being created in the designer? You could
try to delete it.
Jason
On 1/9/2012 6:56 AM, kkp Mising name wrote:
> Jason,
> KKP
Re: Reg: rptconfig files [message #777024 is a reply to message #776977] Mon, 09 January 2012 12:07 Go to previous messageGo to next message
We do have rptconfig files created when we modify the rptdesign files in eclipse. But while deploying to linux servers we deploy only rptdesign. Do you see any issue with rptconfig files being created.?
KKP
Re: Reg: rptconfig files [message #777157 is a reply to message #777024] Mon, 09 January 2012 19:22 Go to previous message
No, they are only created in the designer and store the parameters
values of the last run.
Jason
> KKP
Previous Topic:BIRT installation causing problem
Next Topic:[Embedded Birt] : Migration to 3.7
Current Time: Sat Jul 26 03:23:39 EDT 2025
Powered by FUDForum. Page generated in 0.20719 seconds
