Home » Archived » BIRT » BIRT installation causing problem(Installed BIRT successfully but unable to create a birt project since it is not getting displayed when i create a new project)
BIRT installation causing problem [message #776364] Sun, 08 January 2012 02:04 Go to next message
Hi all,
I have installed BIRT today and the installation was successfull, asked me o restart the eclipse once the installation was completed. But after restarting the eclipse, i am not able to find the BIRT folder/project when i try to create a new project.
When i checked the installed softwares then i can see all the BIRT is installed. Have a look at the attachment. Please suggest if i am missing something. Please inform how to create the new BIRT project.
Bunty
  • Attachment: Untitled.png
    (Size: 44.17KB, Downloaded 171 times)
Re: BIRT installation causing problem [message #776972 is a reply to message #776364] Mon, 09 January 2012 10:48 Go to previous messageGo to next message
Do you have the following installed as well?
Eclipse Version 3.6.2 SDK
DTP Version 1.8.2
EMF Version 2.6.1 Release EMF+XSD
GEF Version 3.6.2 runtime
WTP Version 3.2.3
BIRT 2.6.2 requires these.
Jason
On 1/8/2012 2:04 AM, butny wrote:
> Hi all,
> Bunty
Re: BIRT installation causing problem [message #776996 is a reply to message #776972] Mon, 09 January 2012 11:23 Go to previous messageGo to next message
Hi Jason,
I am using eclipse IDE 3.7. Do i need to install Eclipse Version 3.6.2 SDK also? I mean does the SDK comes along with the IDE or i need to install this as well since i cant find an entry of the SDK in the list of installables.
No i don't have the list you provided installed. Please inform from where to get this. Should i install them individually or i will get all of them in a single package? I am not able to find them, hence asked you about the links where i can get them.
Bunty
[Updated on: Mon, 09 January 2012 11:27] by Moderator
Re: BIRT installation causing problem [message #777004 is a reply to message #776996] Mon, 09 January 2012 11:31 Go to previous messageGo to next message
FYI;
I am using Eclipse Indigo.
Re: BIRT installation causing problem [message #777156 is a reply to message #777004] Mon, 09 January 2012 19:22 Go to previous message
You should be able to get these individually from the update site.
You can also download the allinone download that has Eclipse/Birt and
all the dependencies included.
Jason
On 1/9/2012 11:31 AM, butny wrote:
> FYI;
Previous Topic:Displaying a trademark symbol!
Next Topic:Reg: rptdesign files getting corrupted
Current Time: Thu Jul 24 22:49:58 EDT 2025
Powered by FUDForum. Page generated in 0.28144 seconds
