Home » Archived » Jubula » Using the Value "*" in Data Sets isn't possible(In the AUT it changes to ")")
Using the Value "*" in Data Sets isn't possible [message #774187] Tue, 03 January 2012 08:08 Go to next message
I'm new with Jubula and just running into a little Problem I find no solution for:
In my Testcase for our RCP-Application I use "<ub_cti_replace_Text>[TEXT]" with the Parameter Values:
Parameter Name: TEXT,
Parameter Type: String,
Parameter Value: =MYVAR
In "Data Sets" of the Test Case I enter "*" for MYVAR.
(The application I want to test is a GUI for searching something...and I want to search with wildcards)
When I start the Test, it works as it should, but it enteres "(" in the Textfield instead of "*".
Can you help me with this problem? Thanks in advance!
Re: Using the Value "*" in Data Sets isn't possible [message #774192 is a reply to message #774187] Tue, 03 January 2012 08:27 Go to previous messageGo to next message
For RCP/SWT you have to specify a keyboard layout (which matches your test environment) in the AUT config dialog.
- Achim
Re: Using the Value "*" in Data Sets isn't possible [message #774194 is a reply to message #774192] Tue, 03 January 2012 08:34 Go to previous messageGo to next message
Thank you for the fast help! That really solved the problem... Smile
Re: Using the Value "*" in Data Sets isn't possible [message #776922 is a reply to message #774187] Mon, 09 January 2012 09:43 Go to previous message
No Message Body
[Updated on: Mon, 09 January 2012 10:53] by Moderator
Previous Topic:conditionial testing
Next Topic:Jubula + IE9
Current Time: Sat Jul 26 02:17:27 EDT 2025
Powered by FUDForum. Page generated in 0.04812 seconds
