Home » Language IDEs » ServerTools (WTP) » WTP and JSP/HTML editor
| WTP and JSP/HTML editor [message #77614] |
Sun, 27 February 2005 04:36  |
Originally posted by: nospam.noemail.com
based on this forum information, I've downloaded the WTP project and
included it within Eclipse platform.
I'm quite surprise that nothing was added to New menu (from File), like
JSP file, and so on...
the New menu is still the same (project,folder, file, other).
Is it normal status ?
If yes, what should i do to create a JSP file ? should i select FILE
from new menu ?
Moreover, all tags are not basically colored within editor.
I'm surprised once again that nothing is done in this way.
Is it normal or did i install it bad ?
thx,
Maileen
| Re: WTP and JSP/HTML editor [message #77639 is a reply to message #77614] |
Sun, 27 February 2005 05:31   |
Originally posted by: jmordax.terra.es
Maileen wrote:
> like JSP file, and so on...
> from new menu ?
> thx,
> Maileen
I suspect something is wrong.
Go to: Help -> Software Updates -> Manage Configuration...
Make sure you have "show disabled features" toolbar button pressed.
Expand your installation configuration and make sure that all the new
installed features are there. It they are disabled (I suspect so),
enable them.
Hope this helps,
Chemi.
| Re: WTP and JSP/HTML editor [message #77672 is a reply to message #77639] |
Sun, 27 February 2005 06:03   |
Thanks a lot.
I've found that some jar were missing.
I've installed them and now everything is ok.
Maileen
Chemi wrote:
> Maileen wrote:
>> Hi,
>> from new menu ?
>> thx,
>> Maileen
> enable them.
> Hope this helps,
> Chemi.
| Re: WTP and JSP/HTML editor [message #78809 is a reply to message #77672] |
Tue, 01 March 2005 16:17   |
I'm having the same problem as you. Can you explain which jar files you
are referring to and where they should go?
Thank you.
Dan
Maileen wrote:
> Thanks a lot.
> Maileen
> Chemi wrote:
>> Maileen wrote:
>>> Hi,
>>> from new menu ?
>>> thx,
>>> Maileen
>> enable them.
>> Hope this helps,
>> Chemi.
| Re: WTP and JSP/HTML editor [message #80684 is a reply to message #78809] |
Sun, 06 March 2005 12:05  |
On Wed, 02 Mar 2005 08:17:04 +1100, Dan Simmonds <danoxster@gmail.com> wrote:
This is probably the webservices jars listed in install instructions as optional.
We really did try and make them optional, but apparently its senstitive to the
exact environment, which VM is used, or something.
Current Time: Sat Nov 01 08:25:19 EDT 2025
Powered by FUDForum. Page generated in 0.04663 seconds
