Home » Newcomers » Newcomers » starting eclipse on Linux(eclipse executable not recognized)
starting eclipse on Linux [message #775862] Fri, 06 January 2012 15:20 Go to next message
How do I start Eclipse from the BASH shell?
I've updated the eclipse.ini with:
-vm
/usr/lib/jvm/jre/bin/java
when I type ecplipse at the command line I get:
william@linux-1ro8:~/Documents/eclipse> eclipse
If 'eclipse' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf eclipse
eclipse shon as executable:
william@linux-1ro8:~/Documents/eclipse> ls -l
total 604
drwxr-xr-x 2 william users 4096 Sep 15 22:13 about_files
-rw-r--r-- 1 william users 18909 Sep 9 14:21 about.html
-rw-r--r-- 1 william users 76985 Sep 15 22:13 artifacts.xml
drwxr-xr-x 4 william users 4096 Sep 15 22:13 configuration
drwxr-xr-x 2 william users 4096 Sep 15 22:13 dropins
-rwxr-xr-x 1 william users 71023 Mar 21 2011 eclipse
-rw-r--r-- 1 william users 448 Jan 6 14:54 eclipse.ini
-rw-r--r-- 1 william users 16536 Feb 25 2005 epl-v10.html
drwxr-xr-x 31 william users 4096 Sep 15 22:13 features
-rw-r--r-- 1 william users 9022 Dec 11 2006 icon.xpm
-rwxr-xr-x 1 william users 335360 Dec 11 2006 libcairo-swt.so
-rw-r--r-- 1 william users 8951 Feb 4 2011 notice.html
drwxr-xr-x 5 william users 4096 Sep 15 22:12 p2
drwxr-xr-x 13 william users 32768 Sep 15 22:13 plugins
drwxr-xr-x 2 william users 4096 Sep 15 22:13 readme
Thanks, Will
Re: starting eclipse on Linux [message #775887 is a reply to message #775862] Fri, 06 January 2012 16:39 Go to previous messageGo to next message
Either the ~/Documents/eclipse directory has to be on your PATH or the current directory (.) has to be on the PATH. If not, ./eclipse should run the eclipse executable in the current directory.
Re: starting eclipse on Linux [message #775906 is a reply to message #775887] Fri, 06 January 2012 17:53 Go to previous messageGo to next message
Thanks.
Trying the current directory option I get:
william@linux-1ro8:~/eclipse> ./eclipse
bash: ./eclipse: cannot execute binary file
Re: starting eclipse on Linux [message #776501 is a reply to message #775906] Sun, 08 January 2012 10:59 Go to previous messageGo to next message
Did you download the 64-bit version and try to use it on a 32-bit machine?
Re: starting eclipse on Linux [message #776631 is a reply to message #776501] Sun, 08 January 2012 19:08 Go to previous messageGo to next message
No - 64 bit machine.
I am running through Oracle VM VirtualBox.
Any issue there?
Re: starting eclipse on Linux [message #777092 is a reply to message #776631] Mon, 09 January 2012 15:37 Go to previous message
OK, I have 64 Bit OpenSuse running through VM VirtualBox
I installed the 32 bit Eclipse, and it launches. I'll see how it holds up.
Previous Topic:Shared Object files not compiling with .so extension
Next Topic:Eclipse Package Installation Errors
Current Time: Fri Jul 25 23:59:39 EDT 2025
Powered by FUDForum. Page generated in 0.09273 seconds
