Home » Archived » BIRT » Inserting Background Image Problem(Background image not showing when using onCreate script.)
Inserting Background Image Problem [message #775511] Fri, 06 January 2012 01:06 Go to next message
I am trying to insert a background image using a script but cannot get it to work.
I have a grid on which I have attached the following onCreate script:
this.getParent().getStyle().backgroundImage = "DRAFT-Watermark.JPG";
The image does not show and there is no error in the debug window. I also had the full path included and it did not make a difference.
I am new to BIRT and especially new to the scripting part of the program so I may not be attaching this to the right area.
I am using BIRT 3.7 in Eclipse and I view the report as PDF directly from the designer.
The test report using the sample database and the image I am trying to insert is attached.
Thank you for any assistance,
JB
Re: Inserting Background Image Problem [message #775795 is a reply to message #775511] Fri, 06 January 2012 12:26 Go to previous messageGo to next message
You need to size the grid to fit the image. I modified your example to
put your grid in another grid and moved the script to onRender. Also
make sure the image is in the resource folder or in the same directory
as the report.
See attached.
You may also want to look over these posts:
http://birtworld.blogspot.com/2010/12/birt-backgroundwatermark-images.html
http://birtworld.blogspot.com/2010/09/birt-image-report-item.html
Jason
> JB
  • Attachment: draft.zip
    (Size: 1.87KB, Downloaded 594 times)
Re: Inserting Background Image Problem [message #775820 is a reply to message #775795] Fri, 06 January 2012 13:19 Go to previous messageGo to next message
Thank you Jason. I can get it to work for me now.
I did not realize that I couldn't supply a path to the image.
I also did not realize that BIRT will not resize the grid to accommodate
the image.
I originally had the image as a background in a style but could not figure
out how to use a script to either add or remove the image from that style
or to change styles. What scripts do you need for that?
JB
> as the report.
> See attached.
images.html
> Jason
Re: Inserting Background Image Problem [message #775830 is a reply to message #775820] Fri, 06 January 2012 13:38 Go to previous messageGo to next message
Styles can only be changed in the beforeFactory, so that is probably to
early if you want to changed based on data. It is not to late if you
want to change based on parameter. To drop the image from the grid you
could always use this.getStyle().backgroundImage = ""; in the onRender
script.
Jason
> the image.
> JB
>> as the report.
>> See attached.
> images.html
>> Jason
Re: Inserting Background Image Problem [message #775839 is a reply to message #775830] Fri, 06 January 2012 14:01 Go to previous messageGo to next message
I am changing the background based on parameters so beforeFactory would
actually work. Your solution of setting the backgroundImage to "" is a
good fit for my report.
One of the things that I am struggling with in learning the scripting side
of things is the actual keywords and options for an object.
For example, what would the code be to change a background in a style?
I am spending hours every day just combing through websites and forums
looking for the small snippet of code that will work for me every time I
try to do something new. Overall though, I like the BIRT and am finding
the support very helpful.
JB
> script.
> Jason
Re: Inserting Background Image Problem [message #775845 is a reply to message #775839] Fri, 06 January 2012 14:17 Go to previous messageGo to next message
We have a small primer on scripting at:
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.php
We need to expand this.
When you change styles in the before factory you are using the DE API
and we have a lot of examples and even a webinar on this api at
BIRT-exchange.org. Here is an example
//beforeFactory
importPackage(Packages.org.eclipse.birt.report.model.api);
importPackage(Packages.org.eclipse.birt.report.model.api.elements);
reportContext.getDesignHandle().findStyle("report").setProperty(StyleHandle.FONT_FAMILY_PROP,
"Arial");
StyleHandle.COLOR_PROP, "#009B9B" );
StyleHandle.FONT_WEIGHT_PROP, DesignChoiceConstants.FONT_WEIGHT_BOLD );
//background image
reportContext.getDesignHandle().findStyle("NewStyle").setBackgroundImage( ""
//or use
StyleHandle.BACKGROUND_IMAGE_TYPE_PROP, "" );
Jason
> JB
>> script.
>> Jason
Re: Inserting Background Image Problem [message #775850 is a reply to message #775845] Fri, 06 January 2012 14:37 Go to previous message
Thank you very much.
I will review these references.
JB
> http://www.eclipse.org/birt/phoenix/deploy/reportScripting.php We need
> to expand this.
> //beforeFactory
> "Arial");
> //background image
> //or use
> Jason On 1/6/2012 2:01 PM, JB wrote:
Previous Topic:Graphic appears on some PCs, but not in others
Next Topic:Page numbering by master page
Current Time: Sat Jul 26 23:39:13 EDT 2025
Powered by FUDForum. Page generated in 0.06546 seconds
