Home » Newcomers » Newcomers » [SOLVED] Eclipse Test Cases
icon10.gif  [SOLVED] Eclipse Test Cases [message #769503] Thu, 22 December 2011 02:34 Go to next message
Hi all,
I guess this is two part question:
1- Is there a convenient way to write Eclipse plug-in tests (I guess normal JUnit tests won't work here)
2- Does Eclipse's tests (I am sure they have many) are accessible by public? If yes, could someone give me a link (or a starting point)?
Thanks in advance, best regards,
Edit: The answer given by Dani is exactly right. Thank you Dani,
[Updated on: Fri, 14 December 2012 09:40] by Moderator
Re: Eclipse Test Cases [message #775610 is a reply to message #769503] Fri, 06 January 2012 05:59 Go to previous message
On 22.12.2011 08:34, Kivanc Muslu wrote:
> Hi all,
The tests look the same as normal JUnit tests except that they probably
access the workspace and/or workbench. In order to launch such tests you
launch them with a special launcher (Run As > JUnit Plug-in Test).
Yes, build's download page also has the framework and the tests, e.g.
http://download.eclipse.org/eclipse/downloads/drops/S-3.8M4-201112091447/index.php#JUnitPlugin
Or you can get the source from the Git repositories, e.g.
http://git.eclipse.org/c/platform/eclipse.platform.text.git/tree/org.eclipse.ui.editors.tests
Dani
Previous Topic:Scrapbook
Next Topic:Key Preference Page
Current Time: Wed Jul 23 07:42:39 EDT 2025
Powered by FUDForum. Page generated in 0.08457 seconds
