Home » Archived » BIRT » Page numbering by master page(How to create page numbering for each master page)
Page numbering by master page [message #775333] Thu, 05 January 2012 14:43 Go to next message
I apologize in advance if question has already been asked and resolved in past topics but I have not found anything.
Here is my requirement for my BIRT 3.7 report (using run and output straight to PDF):
MasterPageA (instead of having Page 1 of 2, I am getting Page 1 of 3)
Page1
MasterPageA
Page2
MasterPageB
SummaryPage (always only one page)
I am using auto-text in the header of masterPage. My question is how can I have access to the total-page variable, so I can display in my masterPageA something like (total-page) - 1 ?
Any ideas are much appreciated.
Re: Page numbering by master page [message #775768 is a reply to message #775333] Fri, 06 January 2012 11:42 Go to previous messageGo to next message
When you deploy this report how will you be running it?
Jason
> straight to PDF):
> Page1
> MasterPageA
> Page2
> MasterPageB
> Thanks
Re: Page numbering by master page [message #775801 is a reply to message #775768] Fri, 06 January 2012 12:36 Go to previous messageGo to next message
It will be running using WebViewer with straight output to PDF.
Re: Page numbering by master page [message #775826 is a reply to message #775801] Fri, 06 January 2012 13:34 Go to previous messageGo to next message
When you run the report in the Viewer, if you run to html using the
frameset mapping and then export to pdf does the report come out
correctly? Also try frameset mapping with &__format=pdf appended to the
url.
Jason
Re: Page numbering by master page [message #775853 is a reply to message #775826] Fri, 06 January 2012 14:51 Go to previous messageGo to next message
I am using run mapping with &__format=pdf. Would frameset make a difference?
url.
Jason
Re: Page numbering by master page [message #775869 is a reply to message #775853] Fri, 06 January 2012 15:43 Go to previous message
Yes, frameset uses a run task then a render task. run mapping uses
runandrender task, which does not create a rptdocument.
Jason
> difference?
> Quote:
>> url.
>> Jason
Previous Topic:Inserting Background Image Problem
Next Topic:Birt 3.7 - Frameset mapping crashes my Tomcat server
Current Time: Sun Jul 27 10:00:55 EDT 2025
Powered by FUDForum. Page generated in 0.06009 seconds
