Home » Eclipse Projects » WindowBuilder » JFace(How to create a JFace window)
JFace [message #775278] Thu, 05 January 2012 12:54 Go to next message
I am playing around with WindowBuilder.
I created simple programs using "WindowBuilder/Swing Designer/Application Window" and "WindowBuilder/SWT Designer/SWT/Application Window" classes with no problem.
However, when I tryed to create a "WindowBuilder/SWT Designer/JFace/ApplicationWindow", the source code gave me unresolved imports associated with "org.eclipse.jface...".
What do I need to do to create a JFace based class without all th import errors?
Thanx,
Bill
Re: JFace [message #775292 is a reply to message #775278] Thu, 05 January 2012 13:28 Go to previous messageGo to next message
1. Add JFace biraries from "plugins" folder of your Eclipse, into your project classpath.
2. Just create PDE project and add dependency on org.eclipse.ui plugin.
Re: JFace [message #775338 is a reply to message #775292] Thu, 05 January 2012 14:54 Go to previous message
Note that if you use the SWT/JFace project wizard that comes with WB or the Plugin/RCP wizard that comes with Eclipse, JFace will already be on the classpath. If you create the project manually or use the simple Java project wizard, it is up to you to properly configure the classpath with things like JFace.
Previous Topic:How to avoid default container for JFRAME and for all others also
Next Topic:JList data binding not working.
Current Time: Thu Jul 24 22:28:54 EDT 2025
Powered by FUDForum. Page generated in 0.08262 seconds
