Home » Modeling » M2T (model-to-text transformation) » [Xpand] Generating multiple times to the same file
[Xpand] Generating multiple times to the same file [message #774665] Wed, 04 January 2012 06:14 Go to next message
The XPand reference introduces the FILE statement as a means to create a new file out of a given expression. I have a situation where I not only need to create a file, but also to update it multiple times, each time expanding its contents.
So, is it possible to generate text into an existing file without overriding its contents, or even with respect to its existing contents?
Regards, Daniel
Re: [Xpand] Generating multiple times to the same file [message #774706 is a reply to message #774665] Wed, 04 January 2012 07:33 Go to previous messageGo to next message
Hi, it is possible to configure an outlet to append stuff to a file.
For everything else you have to take action yourself
Re: [Xpand] Generating multiple times to the same file [message #774783 is a reply to message #774706] Wed, 04 January 2012 10:45 Go to previous message
Thanks for your reply.
Since appending isn't a suitable solution in my case, I think I'll have to generate some temporary files and integrate them in a seperate workflow, then.
Previous Topic:Xpand: avoid duplicates?
Next Topic:[Acceleo] *.emtl files missing when building updatesite
Current Time: Sun Jul 27 14:00:33 EDT 2025
Powered by FUDForum. Page generated in 0.86047 seconds
