Problem integrating BIRT 3.7 with jsf using jsf4birt library [message #774775] |
Wed, 04 January 2012 10:24  |
When I followed the steps mentioned on
exadel.org/jsf4birt-docs
except the step for creation of platform in WEB-INF/ directory.
I am getting following exception. I have wasted a lot of time fixing this but was unable to do so.... Jason please help me with this problem.
Thank you in advance.
This is what displayed on console and below that is the message displayed in browser.
javax.faces.FacesException: javax.faces.FacesException: No configuration was defined for birt engine
at com.exadel.jsfbirt.engine.BirtRendererUtils.renderBirt(BirtRendererUtils.java:152)
at com.exadel.jsfbirt.renderkit.html.BirtWrapperRenderer.doEncodeBegin(BirtWrapperRenderer.java:162)
at com.exadel.jsfbirt.renderkit.html.BirtWrapperRenderer.encodeBegin(BirtWrapperRenderer.java:127)
at javax.faces.component.UIComponentBase.encodeBegin(UIComponentBase.java:828)
at javax.faces.component.UIComponent.encodeAll(UIComponent.java:1650)
at javax.faces.component.UIComponent.encodeAll(UIComponent.java:1655)
at com.sun.faces.application.view.FaceletViewHandlingStrategy.renderView(FaceletViewHandlingStrategy.java:399)
at com.sun.faces.application.view.MultiViewHandler.renderView(MultiViewHandler.java:131)
at com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:121)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:139)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:313)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:662)
Caused by: javax.faces.FacesException: No configuration was defined for birt engine
at com.exadel.jsfbirt.engine.BirtEngine.loadEngineProps(BirtEngine.java:122)
at com.exadel.jsfbirt.engine.BirtEngine.initBirtConfig(BirtEngine.java:47)
at com.exadel.jsfbirt.engine.BirtEngine.getBirtEngine(BirtEngine.java:57)
at com.exadel.jsfbirt.engine.BirtRendererUtils.renderBirt(BirtRendererUtils.java:134)
... 31 more
20:17:12,462 ERROR [[Faces Servlet]] Servlet.service() for servlet Faces Servlet threw exception
and in browser the following message
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: No configuration was defined for birt engine
javax.faces.webapp.FacesServlet.service(FacesServlet.java:325)
root cause
note The full stack trace of the root cause is available in the JBoss Web/2.1.3.GA logs.
JBoss Web/2.1.3.GA
0
FUDForum. Page generated in 0.32132 seconds
