Home » Eclipse Projects » Rich Client Platform (RCP) » Dynamically create eclipse main menu item or global toolbar item(Dynamically create eclipse main menu item or global toolbar item)
Dynamically create eclipse main menu item or global toolbar item [message #771659] Tue, 27 December 2011 16:21 Go to next message
Appreciate if I can get some helps on the following issue:
I need to create menu items on eclipse main menu bar and toolbar items on eclipse global toolbar when a viewPart instance is created and to remove those menu items when the viewPart instance is disposed.
I tried the following eclipse APIs but could not make them to work:
org.eclipse.ui.menus.IMenuService
org.eclipse.ui.menus.AbstractContributionFactory
org.eclipse.jface.action.ToolBarContributionItem
org.eclipse.jface.action.MenuManager
org.eclipse.jface.action.ToolBarManager
The first issue I am facing is how to define the location where my menu item or toolbar item will be contributed.
Re: Dynamically create eclipse main menu item or global toolbar item [message #774723 is a reply to message #771659] Wed, 04 January 2012 08:31 Go to previous message
Use the org.eclipse.ui.menus extension point to add your commands to the main toolbar or main menu. Use a visibleWhen clause to make them visible when your view is active, or a visibleWhen + a property tester to have them visible when your view is open.
See:
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse.platform.doc.isv/guide/workbench.htm
PW
Previous Topic:Enable handler based on active page in multi-page editor
Next Topic:Enable "Always run in background" for Jobs as Default
Current Time: Wed Jul 23 07:31:41 EDT 2025
Powered by FUDForum. Page generated in 0.19609 seconds
