Home » Eclipse Projects » GEF » Eclipse does not close until GEF editor is closed(Eclipse does not close until GEF editor is closed)
Eclipse does not close until GEF editor is closed [message #757794] Mon, 21 November 2011 12:29 Go to next message
I've developed a GEF editor application. For some reason, when i click the eclipse IDE "close" button it does not actually close the IDE until i close my opened GEF editors or delete all figures from them.
After closing editors or deleting figures eclipse gets closed, throwing the following exception:
!ENTRY org.eclipse.ui 4 0 2011-11-21 18:17:52.489
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1688)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:734)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:710)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:832)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:830)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:687)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1282)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1267)
at org.eclipse.swt.widgets.Shell.closeWidget(Shell.java:616)
at org.eclipse.swt.widgets.Shell.gtk_delete_event(Shell.java:1166)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1735)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4796)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4360)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:8189)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1238)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2237)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3159)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
I know this won't be enough information to help me solve the issue, but i'm really lost. I don't know what to trace or whatever... Any clues?
Re: Eclipse does not close until GEF editor is closed [message #774645 is a reply to message #757794] Wed, 04 January 2012 05:38 Go to previous message
Kindly check whether you have done any paintFigure in your corresponding figure class. Sometimes it may execute your loop and it wont close. First of all identify when it happens and what are all the shapes available in the editor.
Thanks & Regards,
Karthikeyan.B
[Updated on: Wed, 04 January 2012 05:39] by Moderator
Previous Topic:Open a new shape editor instance
Next Topic:Direct edit with toolbar
Current Time: Fri Oct 24 07:27:50 EDT 2025
Powered by FUDForum. Page generated in 0.03717 seconds
